Old 12-01-2007, 06:24 PM
44propmaker is on a distinguished road
Cool What size table for 90 Oz/INCH TORQUE motors
Anyone have any suggestions on what my limitations might be. I bought a driver board which came with 3; 90 Oz/INCH TORQUE motors. I'm just trying to get my feet wet so to speak. The board and motors can be seen here:
http://cgi.ebay.com/3-Axis-CNC-Route...QQcmdZViewItem
Any and all comments will be greatly appreciated.
Old 12-06-2007, 12:28 PM
DistortedDesign is on a distinguished road
With 90oz motors you are going to be fairly restriced on the size. I am not an expert from everything I have read and seen you are looking at a small hobby sized cnc or a pcb cnc. I wouldn't make anything above 18" x 18" cutting area. You may have a hard time doing some woods. You should be able to do the softer woods, foam, and plastic. You will have to try and make sure you z axis is fairly light weight. Just to put it in perspective, if you look at all of the plans most of benchtop sized cnc's like jgro's plans, or joes wood design are using 196oz motors or 296oz if you want more ipm. If you go to instructables.com and search for cnc there. A guy has complete video instructions on how to build a cheap cnc and should work fine with your motors.
XY table design basics, linear ways to table size ratio? Konstantin Mechanical Calculations/Engineering Design 0 03-13-2007 01:21 PM
4 inch rotary table for CNC, which has worked best replicapro Benchtop Machines 13 07-15-2006 11:49 AM
Wich Size/Torque? samsagaz DIY-CNC Router Table Machines 0 07-12-2006 12:57 AM
200oz motors vs. Table size? CoffeeRich Hobbycnc (Products) 9 01-15-2006 04:57 PM
850 oz/inch HOW TO SIZE SERVO MOTOR (CNC ROUTER) bradyfb Servo Drives 4 11-20-2005 08:31 AM
