| Hey... was doing the search looking for rails and came across these rails And so I thought I would ask what you all thought about them |
| Seems like a few members have "talked" about them - but I haven't seen any feedback from using them. There are a few that use the 80/20 (including myself) for the frame and supports and it seems like a "natural" to use the slides too. The Bosch and other types have a slide I recall too. There is often some of used gear "about" that may be a little cheaper too. Maybe I'll have to take the plunge at some point and buy a pair to find out for myself. Anybody?? Cheers - Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| I have some of those 80/20 slides for another purpose. They won't work well for a CNC rail. Too much slop and if you get the slop out, they bind. Aluminum extrusions aren't dimensionally straight enough for the accuracy you need. So you have to keep the bearing surface quite loose to avoid binding. |
| Geez fellas .... I used linear slides from Futura (the T-slots people) for a panel saw that I built. I used the 'wide' (3 inches???) versions and they worked great. So great that I was thinking of using them for the CNC wood router that I am planning. Are you sure that they are that bad??? |
| buscht , In my case I used four 3 inch wide bearings where I could have gotten away with two. Could I have inadvertently eased the problem that you describe because I have so much slide surface area in contact with the aluminum extrusion? I didn't go out of my way to 'overtighten' the slides either. In my case I used the the 1.5 by 3 inch extrusion on edge as I was looking to reduce errors due to the 'mid beam' deflection of the extrusion. The extrusion is unsupported over a 4.5 foot distance. Or perhaps the error is there and I just don't see it because I am cutting down 4 by 8 foot panels for cabinetry. Hmmm ... I hope someone speaks up that has experience using them for CNC applications. |
| gas pipe & linear bearing dimensions relationship | zoltan | Linear and Rotary Motion | 6 | 06-13-2005 03:12 PM |
| Linear Bearing mat’l? | jakk100 | Linear and Rotary Motion | 19 | 05-18-2005 12:15 PM |
| a cheap linear bearing | mocnc | DIY-CNC Router Table Machines | 8 | 03-26-2005 04:52 PM |
| Linear bearing spacing & Sizing linear rails? | fyffe555 | DIY-CNC Router Table Machines | 3 | 12-07-2004 01:09 PM |
| build your own linear bearing | CNC Brute | DIY-CNC Router Table Machines | 4 | 02-07-2004 03:32 AM |
