Old 11-24-2007, 10:14 PM
david90 is on a distinguished road
having trouble finding this part
I have a 3/8-10 acme lead screw and I'm having trouble finding a 3/8-10 nut with this style
http://cgi.ebay.com/Acme-1-2-10-Delr...QQcmdZViewItem
I tried googling but all I found was hex and flange mount style. Could somebody point me to a site that has this style of acme nut?
Thanks a lot
Old 11-24-2007, 10:36 PM
ger21's Avatar
I think you'll need to make your own, as those are probably made by the Ebay seller. Or pay someone to make them for you. I've never seen a nut like that anywhere before.
Old 11-24-2007, 10:58 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Dumpstercnc.com
Old 11-25-2007, 01:37 AM
runchman is on a distinguished road
You could look at mcmaster.com page 1053, they have some acme 3/8-10 nuts that are extra large so you can machine them, perhaps that would be an option?
- John
Old 12-07-2007, 06:56 AM
csrc is on a distinguished road
I am not sure what your app is, but I built a machine some time ago with 3/8 acme with a plastic nut and found it quite limiting. Had to retrofit to a larger size as the shaft got hot and the nut stripped out. Speed and load must be kept quite low.
Old 12-07-2007, 01:27 PM
gmfoster is on a distinguished road
But he isn't asking about plastic, he specified Delrin..
Garry
Old 12-13-2007, 06:32 AM
Not to make too fine a point of it, but the ones we destroyed were also Delrin. We were also using stainless shafts. Point is, they don't like speed.
Need help finding CNC tutorial on the web!! NewCents DIY-CNC Router Table Machines 3 04-10-2009 04:08 PM
need help finding a cnc lathe joey1117 General Metal Working Machines 2 02-07-2007 05:02 PM
Help finding a part fishmasterdan Welding, Brazing, Soldering, Sealing 0 10-22-2006 12:15 PM
Finding Ballscrews ronald44 General Metal Working Machines 7 04-19-2006 12:45 AM
Need help in finding brtlatjgt General CNC (Mill and Lathe) Control Software (NC) 1 06-03-2005 12:31 PM
