Old 11-22-2007, 02:19 PM
Cartierusm is on a distinguished road
Help Me Get My Balls Back In
I know what you're thinking when you read my title, but it's not what you think.
I have a 5/8" Roton Ball Nut and some of the balls fell out when threading it on to my ball screw even though I used the little cardboard tube insert. The blokes as Roton said a few balls won't make a difference, but 3 balls seems too much.
So what's the easiest most painless way to get balls back into the ball nut.
Old 11-22-2007, 02:55 PM
dpmulvan is on a distinguished road
There is no way
Old 11-22-2007, 03:03 PM
Cruiser is on a distinguished road
Simple, get a pie tin and pull the external ball run from nut, using pie tin to catch, insert all the balls with nut on screw and all you may have to do is vasaline the loose balls to the ball run and reinstall, make sure that no balls are outside of race but inside of wiper, may be easier to just dump all the balls from nut to the pie tin and have some enjoyment, Happy turkey day
Don
IH v-3 early model owner
How many balls in nut? phantomcow2 Linear and Rotary Motion 10 04-19-2007 11:30 AM
detent balls norvil1 General Metalwork Discussion 7 02-08-2007 07:51 PM
I need 1 7/8" aluminum balls carbidecraters Employment Opportunity 4 12-15-2006 02:14 PM
Lost Balls for THK HSR15 Help planekrazie Linear and Rotary Motion 2 08-13-2006 10:14 PM
Ballnuts: Do you really need all the balls? geohot Linear and Rotary Motion 3 12-27-2005 01:34 AM
