Old 11-12-2007, 12:29 PM
Darren is on a distinguished road
Rack and pinion or ACME?
Hi guys,
I have all my linear rails etc. and need to decide whether to use rack and pinion or ACME screws. Is it harder to manage backlash on one or the other? It appears rack and pinion is easier on the wallet but ACME screws aren't terribly expensive. Ball screws are pretty spendy and I'm kinda avoiding that cost.
Here is my thread describing my current parts obatined. This will be a pretty high end router. All aluminum and steel with supported Thomson rails all the way around. 30" X 48" X 18"z. 450oz servo's etc...
Overwhelmed, have many parts... need guidance
Any advice on pros and cons of either or other ideas would be great. Looks like I could use a 4:1 reduction. I'm dreading figuring out how to get the machine work done on ACME screws which is why rack and pinion caught my attention.
Darren
www.garagehobbies.com
Old 11-12-2007, 01:03 PM
LeeWay's Avatar
LeeWay is on a distinguished road
Actually both have good and bad points. I haven't yet tested my plasma that I am building with R&P. If you don't have a lathe to turn your screws, this may be the way to go.
You do need a spring loaded mechanism on them to try to keep pressure or contact between the rack and gear as it changes direction. I have seen these simple and complicated. My particular build has a jack shaft to drive the X and it took me awhile to get the design down. I think it should work great, but as yet untested. I think it is also easy to install and maintain. Can be installed upside down to alleviate trash on it. It will allow faster speeds on larger machines.
I initially bought Acme rod to build my first router with. I bought store bought brass nuts. Terrible fit on these things and they really weren't cheap. At that point, I decide to go with ball nuts and screws. I still have the acme rod and may use them with some Dumpster nuts. They look well made and will make acme acceptable. Not bad price wise either.
For a machine your size, I would likely go with acme and Dumpster nuts given the two choices. Either will work, though.
Good luck with it.
Lee
Old 11-12-2007, 02:15 PM
wcarrothers1 is on a distinguished road
Well I did rack on my long axis. And like it. How ever I would love to have more gear reduction. But unless you pinion is REAL small I'd say 4:1 on servos is not enough. I'm running 10:1 planitary (thompson tranny) with a bit of a belt reduction after that to 1" diam pinions to my rack. I can fast jog up to 800ipm how ever i've got more RPM left on the top end of my servos even at that thus more gear reduction would alow me to up my resoloution a bit on the axis.
b/
Old 11-12-2007, 02:19 PM
Yeah, the 4:1 reduction was for the acme screws that were recommended to me. I have no idea what is needed for R&P.
Thanks for the info so far guys.
Darren
Old 11-13-2007, 01:39 AM
Cartierusm is on a distinguished road
What's your price range???? I started out with McMaster Carr Acme Screws and Dumpster Anti-Backlash nuts and just recently discovered Roton..dirt cheap, if you don't buy the mounting flange. The dumpster nuts are like $18, the Roton ballnut is $22.50 for 5/8", and the ballscrew is about $1 an inch, that's cheaper than Mcmaster for the acme screw. So in my opinion go with ballscrews, I just ordered mine to convert.
Old 11-13-2007, 09:31 AM
I don't have a set budget, just trying to remain reasonable. If I can find ball screws for that cheap then I'll go ballscrew! Now I just need to figure out which ones I need and look into that as well now.
Darren
Old 11-13-2007, 12:46 PM
I'm a little confused. The prices are all over the place. Is this what you are looking at? http://www.roton.com/Mating_Componen...family=7059321
I'm having a terrible time determining what pitch etc... Every step I take it gets more complicated to get this right.
Darren
Old 11-13-2007, 01:35 PM
Yes, the 5/8" x .200 is the most resonable price there. It takes 5 turn per inch.
Old 11-13-2007, 01:36 PM
Sweet! That is an excellent price, looks like I'll be considering ballscrews. How will you turn them down to fit the bearings for mounting etc?
Darren
Old 11-16-2007, 11:47 AM
Glidergider is on a distinguished road
How long is your screw going to be? That's a key design point. If you are greater then 4 feet, then the rack in pinion is probably your best bet. Longer then 4 feet and your spinning rod will develop a significant wobble. I didn't look in detail at your other build thread. That's why I don't know how long your table is.
How fast do you want to jog and cut? Most guys are going with the 1 inch diameter. Enco.com sells a 1 inch 10 tpi single start acme for $10/6feet. I bought a 1 inch/10tpi, 2 start acme for $60/6 feet. You can jog a bit faster with the 2 start.
Dave
  #11   Ban this user!
Old 11-16-2007, 11:52 AM
My longest axis is 48" but the travel will be a few inches short of course. I'm not sure I want to deal with the ballscrews right now so I'll probably begin with acme screws.
I'm not sure how fast I want or need. I just want to take advantage of my servo's and run them at what would be considered to be a respectable level of their overal capability. I'll be cutting aluminum and wood.
Darren
Old 11-16-2007, 02:35 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
acme screws 1/2"-10 5 start, will work nicely for that size.
Joe
BALLSCREW vs. RACK & PINION vs. PRECISION ACME SCREWS Chivo Linear and Rotary Motion 2 07-28-2008 08:42 AM
Considering rack and pinion phantomcow2 DIY-CNC Router Table Machines 12 03-12-2006 05:05 PM
rack and pinion senor J. Linear and Rotary Motion 7 11-17-2005 05:21 PM
Rack & pinion coolman DIY-CNC Router Table Machines 3 11-30-2004 11:57 AM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 10:36 PM
