#13
#14
#16
| Sorry, I can't help you. I don't have that hardware. |
#17
#18
| No 5 start, two turns per inch, trust me it is very smooth and dumpster nuts work great with it. McMaster-Carr Part Number: 99030A704 Joe |
#20
| Personally I think it may also depend on the type of bearings you use, but at two turns per inch, that sucker should fly. You may need reduction to just gain torque though. The screws I am using on my mill are 1 turn = 10 mm. That is a pretty high helix as well. I have chain drive gears on the Y and have tested that and quit at 120 IPM. For an 8 or 9" axis, that is plenty. No need to go higher, but will likely set it at about 80 IPM rapids. The gearing on it is 3 to 1. Probably way to much, but I will let the machine cut new parts when it is done, then change it to a belt drive about 1.5 to 1. I got to work on my X this afternoon and just need to mount the motor now. May do that in the AM.
__________________ Lee |
#21
| If you go back to your other thread, Jeff said you should run those servos at about 2500rpm. 5 start 1/2-10 screws are 2 turns per inch. You need to pick a target top speed, and gear to that. If you want to go 250ipm, that would be 500 rpm at the screw, and 5:1 gearing.
#22
Wow, I'll bet that really moves out. Yes, very smooth. What jog speeds do you get, 200ipm? |
#23
| I have the 5 start 1/2-10 with Dumpster nuts on my machine. I'm using 3' screws on both axes. I get rapids of 300 IPM on my Y, and I've gotten 600 IPM (that's no typo) on my X. They're wicked fast, and help a lot with whip. Ahren www.cncrouterparts.com |
#24
| Darren, I am building a machine using the 5/8-.200 ball screw set up. My long axis is 48". I am using 12mm ID 6201rs ball bearings (dirt cheap from VXB). This is just less than the root of the thread so it cleaned up nicely on the lathe. The OD will press fit into 1.25" with some forgiveness (1.2594" in theory). I combed CNCZone before I spent my dough and the majority say that ballscrews are the way to go. Lots of commercial machines use R+P, but the 5/8-.200 ballscrews are cheap! You must factor in the cost of a tap for the ballnuts, however, as the 15/16" - 16tpi tap is pure unobtanium except from Mcmaster ($58), unless you pay the premium for the prethreaded flanges. I think it is worth it to eliminate backlash and wear. Last edited by csrc; 12-07-2007 at 06:37 AM. Reason: addendum |
| BALLSCREW vs. RACK & PINION vs. PRECISION ACME SCREWS | Chivo | Linear and Rotary Motion | 2 | 07-28-2008 07:42 AM |
| Considering rack and pinion | phantomcow2 | DIY-CNC Router Table Machines | 12 | 03-12-2006 04:05 PM |
| rack and pinion | senor J. | Linear and Rotary Motion | 7 | 11-17-2005 04:21 PM |
| Rack & pinion | coolman | DIY-CNC Router Table Machines | 3 | 11-30-2004 10:57 AM |
| calculatiing pinion size for rack and pinion setup | Apples | DIY-CNC Router Table Machines | 3 | 05-18-2004 09:36 PM |
