Old 11-10-2007, 09:03 PM
eloid is on a distinguished road
can you say OMG!!!!!!!!!!!!!
cnc router lath....
I want this... !!!!!!!!!! NOW!............lol
http://www.youtube.com/watch?v=GcWiFiwCxG0
search Thermwood Corp. on you tube for
Thermwood Corp. CabinetShop 45 Rotary Axis Machining Leg
http://www.youtube.com/watch?v=bV42O09JnOk
search: look for Model 80 Carving Machine
if caps are issue do above search on your own...
Old 11-10-2007, 09:14 PM
ger21's Avatar
The links won't work right now, because the admin has caps turned off.
Old 11-10-2007, 10:54 PM
epineh is on a distinguished road
I don't want one.... I want two !!!!!
Russell.
Old 11-10-2007, 11:06 PM
santa bag
santa only has room for one ....each in his bag
Old 11-11-2007, 05:27 PM
teaching tool paths
Does anyone, who has see the video know... if you can edit travel paths in mach 3 like the video ..ie teach the system how maximize its tooling efficiency with a digitizer?
Im just design my cnc system still, have not used mach 3 or beta vers. yet.
but like what i seen in the video....
Old 11-11-2007, 09:15 PM
ger21's Avatar
You need 5 axis CAM software to create g-code for that, and I'm not sure that Mach3 can even run that code.
Old 11-11-2007, 09:31 PM
optimizing tool paths
for programing 45 Rotary Axis Machining Leg....
is the a way in general ... to opitimize tool paths as showen in video
for flat carvings?
Old 11-11-2007, 09:36 PM
ger21's Avatar
That's something the CAM software does. And what you're seeing there doesn't come cheap.
Old 11-11-2007, 09:42 PM
ger21's Avatar
Sorry, I hadn't watched the second video where the guy creates the toolpaths by dragging a probe across the part. That's probably proprietary Thermwood software that does that.
Also, it's not 5 axis like I said before, but continuous 4 axis. Good 4 axis software should be able to create toolpaths like that, but again, they aren't cheap.
