Old 06-11-2004, 10:40 AM
musicmkr is on a distinguished road
El-Cheapo build questions
I'm new to CNCZone, and fairly new to the hobby. I should be finishing up my first desktop machine next week but I wanted to run a few details of my machine past you all and see what you think. Keep in mind as you answer that I'm only looking for accuracy of about .03.
Machine Basics:
-Aluminum 2"x4" tube frame.
-Moving surfaces 1" thick HDPE
-Part moves in Y Direction
-Spindle (dremel) moves in X and Z
-Machineable area 8"x7"x3.5"
-drive system is a belt drive, running 1:1 ratio to a 1/4"-20 rod in all directions.
Question 1 - The 1/4-20 rod spins in two mounted 1/4" needle bearings. (ie. I'm not turning down the shaft to remove the threads) Will this be a problem as long as load the bearings axially with a nut at either end?
Question 2 - Should I bother cutting a keyway into the plastic pully and threaded rod? Or can I simply thread in two machine screws through the pully hub?
Question 3 - I do not plan on using linear bearings. Instead I plan on having the 3/8" thompson rod slide directly through the 1" HDPE. Should this be a problem other than with long term wear and tear on the holes in the plastic?
Question 4 - Is it better to mount the lead screw A) directly between the slide rails, B) Opposite slide rail plane from part, C) Between slide rails and part?
Thanks for all your help!
Old 06-11-2004, 03:35 PM
Chagrin is on a distinguished road
1) With the size of your router and your accuracy requirements, you probably didn't even need any bearings. My router just has the 1/4-20 rod flopping around in slightly oversized holes and I don't see where it has caused any issue. Allowing the threaded rod to push (and move) the shaft of the stepper motor is probably the larger problem.
2) You might also try just jamming the pulley between two nuts (with lockwashers) before you start drilling or cutting at it.
3) Shouldn't be a problem, but try to keep a lot of distance between the two HDPE "bearings" that are sliding on the same rail to prevent binding. Even wooden bearings can be successful when done this way.
4) Directly between the slide rails. Again it's the issue of binding.
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
1st build: Router/Plasma krebsatm02 DIY-CNC Router Table Machines 9 06-25-2005 09:56 AM
looking for the best way to build one of these tables chiliuno CNC Plasma and Waterjet Machines 3 03-31-2005 12:09 AM
Newbie CAM questions WoodSnarfer General CAM Discussion 3 11-12-2004 07:15 AM
Some Gecko 201 Questions mikie Gecko Drives 3 08-09-2004 11:40 PM
