Old 11-09-2007, 11:27 PM
eloid is on a distinguished road
tuning servo motors for rack and pinion design
I want to know what required to tune a dual drive (servo motor) system for a U frame 4x8 table... whats needed to done what are the steps etc...
whats the pro and cons vs steppers setup?
see attached pic
Name:	p-3dmotion motor pic.jpg‎
Old 11-10-2007, 11:28 AM
Al_The_Man's Avatar
I am not sure whether you can use dual servo drive unless the loop is closed in the controller such as Galil etc, where you can use electronic gearing.
one motor is slaved off the masters encoder, although the slave does still have an encoder also, with this system you can even change the 'gear ratio' to whatever you wish .
Systems that use steppers can do it because the motors are synched by the identical stepper pulses.
rack&pinion new design bekx Linear and Rotary Motion 8 08-10-2007 05:12 PM
Anyone got any tips for tuning servo motors? Darc CamSoft Products 25 05-08-2006 01:13 PM
Rack & pinion coolman DIY-CNC Router Table Machines 6 05-07-2006 05:14 PM
Rack and pinion and stepper motors Apples DIY-CNC Router Table Machines 17 05-22-2004 08:53 PM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 10:36 PM
