Old 06-10-2004, 10:36 PM
broncosis is on a distinguished road
materials
I'm new here though before
I started posting I did do plenty of reading and I have question to ask
and I'm sure there will be more
first of all why all the aluminum ?
Steal is stronger cheaper and easier
to find or at least as easy to find
though steal is a litter bit harder to work with but not that much
it is far stronger.
yes it is heavier but the wieght to strenght differnce isn't that much
I'm sure some of the people here
that are rather prolific posters will have a sound answer for this I must be over looking something
Old 06-10-2004, 10:43 PM
duluthboat's Avatar
duluthboat is on a distinguished road
Aluminum can be worked in most cases without machine tools, so it is a good choice for the DIY'er.
Gary
Old 06-10-2004, 11:00 PM
but for the average DIY which includes me even with a entire welding shop that
I could use to build this thing granted that is a hours drive from here
I still don't have a acurate drill press
but I have a great deal of mdf experince
bah the dust what dust
what would the average DIY make that would need machining you can't bandsaw steal as easily this is true but a $40 grinder is a lot cheaper than a band saw
and it will cut and shape both steal and aluminum
ok wait a minute I have to be careful here I don't want to start a flame war with my 4th post on this board
I can drill steal just as easy
and tapping and gettinga good tread is much easier althogh the sprial tap
does make aluminum much easier to tap than with a plain tap
Old 06-10-2004, 11:06 PM
yukonho is on a distinguished road
Working steel would take much more effort than aluminum or mdf. I built my MDF machine (2 of them actually) in my dining room. I used a cordless drill and a jig saw. That's it, a cordless drill and a jig saw.
I got the MDF cut to size at home depot with their panel saw.
The aluminum was the worst part by far. Can you imagine working steel in your dining room? Granted, most people will have better facilities than me, but the bottom line is, it takes a lot more "everything" to build with steel.
co
Old 06-10-2004, 11:13 PM
yukonho
I know excatly what you mean my bed room and the living room here
are basicly where the work gets done I have a smal wood shop
where I do the bigger stuff I build custom sub boxes lots
and my car port is where the truck get fixed but smallings like seats and such
and the finishing work on any sub box are typicly done on my coffee table in my basement/bed room
but if you can build a machine with a jig saw and a cordless drill then I feel I should be ok
with mine once I get my plan sorted out as I don't have a drill press but I'm seriously thinking about one
Old 06-10-2004, 11:15 PM
CrazyRonny's Avatar
CrazyRonny is on a distinguished road
"Steel is stronger cheaper and easier to find" and the mass of steel make a good vibration damper. But the weight is a factor too, for the base and fix part no problem. But for steel moving part the weight of it will demand you bigger stepper to move all that weight, acceleration and deceleration will have to be slower. And bigger stepper mean more $$$$.
CrazyRonny
Old 06-10-2004, 11:24 PM
I don't see the wieght to be that much greater
as you will use much less steal than aluminum
but I may have a scewed perspective
on this as the steal I use is generaly free
now if tools were just that easy
I don't plan on using much on this machine but after a couple of cheap machines so I know what works and what doesn't and I have the hang of running a machine I'll be building a plasma table with someone elses money sort of turning a hobby project into a job
Old 06-11-2004, 01:16 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
Broncosis, I agree. I love steel.
You can easily weld it and drill it, etc. There is something truthful about steel.
You can look at a structure made with steel and just know it will last for a life time. ( Disregarding the rust factor)
Not to mention its cheapness too.
Old 06-11-2004, 01:46 AM
samualt is on a distinguished road
broncosis:
My whole machine will be aluminum in the form of 80/20 T-slots. It is a 4'x8' machine. I can bolt stuff together in different ways, easily add or remove things. Heck, I could change the whole configuration in a day or two. I will be able to disassemble it and store it. I can move whole sides by myself with no help. You can't do most of that with a steel machine.
It's a trade off. With steel you get weight and stability which probably means better accuracy. But with aluminum you lightness, portability, and ease of construction/reconstruction. It depends on what your looking for.
Old 06-11-2004, 03:09 AM
80/20
doesn't realy count as far as I was talking you don't find steal extrusions
I was thinking for plate and raw stock type use
but the tinker toy meathod is a good one
and I was courius to see how well the 80/20 slides worked
and if I was going to build a machine I wanted to take apart it could be done with steal just as easy
but most of the uses I se for aluminum
could be done with steal in half the size where you might use a 1/2" aluminum plate 1/4" steal will still be stronger
but I think I have worked with steal so much I may be biosed that way
welding aside as that is out of a DIY's abillity or resource scope
it takes threads better than aluminum
it drills just as easy with a grinder it cuts plenty easy tools don't plug up cutting steal and I have even cut
1/4" with a cordless sawzall so a corded jig saw should be able to as well but a hacksaw works too
  #11   Ban this user!
Old 06-11-2004, 06:33 AM
balsaman's Avatar
balsaman is on a distinguished road
Aluminum is shiney. Steel is not. It's a cool factor thing. We would use titanium or stainless if you could afford it or machine it, but we can't so aluminum it is.
Steel is a dinosaur.....
Eric
I wish it wouldn't crash.
  #12   Ban this user!
Old 06-11-2004, 08:28 AM
duluthboat's Avatar
broncosis,
First before I forget, welcome to the forum. Doing it yourself, is using your individual knowledge and skills. In most cases there are better ways of doing it but for one reason or another they may not be practical. It is always good to see different approaches to the same problem. Keep posting here; I’m sure we will learn something from each other.
As for using steel, I say, go for it.
Gary
Where do you get materials... cheap? Sporqster General Metalwork Discussion 17 06-19-2005 03:36 PM
Materials ryanduc General Metal Working Machines 1 10-09-2004 01:12 PM
PRACTICE Materials ?? High Seas General Metal Working Machines 6 02-07-2004 05:33 PM
Reality check, materials checklist for electronics Darren_T DIY-CNC Router Table Machines 10 12-04-2003 08:36 PM
Got a jump start on building materials for my CNC Router Darren_T DIY-CNC Router Table Machines 3 11-16-2003 07:13 PM
