I am building a small table top 3 axis machine mostly for foam/plastic/wood, using a Dremel as the spindle. The frame is 2"x4" aluminum tube, and most surfaces are 1" thick Polyethylene sheet. Since I am trying to keep the machine as small as possible, I have found that with my current design, it would save a lot of space to have the Z axis stepper Ride along with the Z Axis itself. I am not sure of the motor specs but they are somewhere around 75 oz in, and there are 4000 steps per inch, with an overall travel of 3 inches. Is there any reason why I should avoid this, and re-design so that the motor is not on the Z axis? Thanks for your help. Ryan |
| On a gantry, I always thought the z did carry its motor, are you sure you do not mean the Y? Al Forget that last statement, I see what you are getting at, I can not see any problem as long as the weight of the motor is figured into the z axis load.
| I just re-read what I wrote, and it wasn't quite clear. What I want to do is have the Z axis Stepper, move up and down with the spindle. I don't see it being a problem as long as the motor can lift the extra weight. I just didn't know if there was a reason that this would be bad, like if the motor would twist the spindle mount as the Z stepper feeds up or down. With all the compromises I have made to make this a cheap project, I probably shouldn't worry about it. |
| A Axis and Step and Direction Spindle Setup | mklb | Mach Software (ArtSoft software) | 6 | 11-27-2009 07:19 AM |
| 3 axis setup: 2 motors work fine, 1 locks up | chozo | Stepper Motors and Drives | 57 | 11-03-2004 07:57 PM |
| software for 4 axis zylotex/sherline setup | shindin | Xylotex | 2 | 10-15-2004 04:58 PM |
| Z axis setup | MrBean | DIY-CNC Router Table Machines | 4 | 09-26-2004 11:55 AM |
| My Lathe project; might CNC it one day | Stevie | General Metal Working Machines | 86 | 06-21-2004 08:27 PM |
