I am looking to get some input on the trade offs between selecting a moving gantry or a moving table for the X-direction. If I am targeting about a 3 foot X direction, which seems to be the consensus for an open CNC design. the moving gantry would result in a smaller machine. The lenght of the machine would roughly be the length of the gantry travel plus the width of the gantry. A moving table would be roughly twice the length of the table ( 6 feet) as both ends of the table need to be positioned underneath the table. The other considerations are the stability of the moving componenet. The moving table seems to be the best from a predicatable platform as it would be easiser to create a stable platform for several reasons: 1.) the rollers would be farther apart, say at the four corners of the moving table. This would result in a less movement at the router head given a fixed movement at a bearing on track movement. 2.) The primary force of the router would be down and be the same direction as gravity driving the table onto its track instead of lifting it off the track as in a moving gantry version. The moving gantry version has the advantage of being smaller and thus costs less as the cost is directly proportional to the size and amount of materials used. The question is can the performance disadvantages be minimized or eliminated to the point to make this the best choice. Any thoughts? Greg |
| One of the down side to a moving table would be that if work of appreciable weight is carried then the motor torque may have to be increased accordingly. i.e. higher mass to move. Al
| The main thing a moving table design has against it is the extra space it requires for the same cutting area. Other than that, it's a stronger and easier to build machine. As well as maintain. Picture #1... There are few, if any, moving gantry machines that'll be stronger than that. There will be no twisting/skewing/racking of a moving gantry...because it doesn't move. The table rides on 4 widely spaced bearings, so it won't rack either. The nut can be supported to prevent whip at each end of the table. A finer pitched screw choice will give it all the mechanical advantage it can use, though only slightly slower cutting speeds, but still well within a range it can cut in any practical manner anyway. Well, that machine's a big industrial beast.... Picture #2... Looking at that machine and asking why it's made like it is points to a need for extreme rigidity. It must do some very highly precise work to need that kind of strength. It's pretty easy to copy the basic design of it for hobby purposes and still get many of the advantages such a machine can give. Mine is just a big MDF version. The table is a separate element in the design that can very easily be slightly adjusted to as near perfect square with the gantry as possible. The bridge can be built in such a way as to make raising or lowering it a simple thing to do for doing something like computer case or large electrical box work where project height can matter. Just a few bolts will easily lower or raise the bridge. Picture #3... A prototype that proves it works Great. It's a lot more rigid than my larger moving gantry machine. Easier to maintain...A moving gantry can be a PITA to get square and adjusted to prevent possiblity of skewing. This isn't. It's cheap & easy... ![]() But it really all depends #1 and Foremost on what you need from the machine. It can be useful to think of these type machines as "special purpose" machines. There's a "right design" for any particular type of project. Mine will cut about 24 x 15 x whatever depth I want to adjust the bridge to....so it's *Ideally* suited for something like a guitar body....where things need to proceed as well as possible on an expensive chunk of Nice wood.... ![]() (Do Not want any chance of things going wrong halfway through a job like that! Things going wrong are minimal with a simpler design) Sure it takes a bit more space for the moving table/fixed bridge design, but again, it depends highly on what the machine needs to do. Large signs may very well need a moving gantry...just for the large-ness of the project alone. I don't build a machine any larger than it needs to be for any type of work it'll do. The smaller the machine can be, the easier it can be to build and maintain. The simpler it is, the less maintaining needs to be done... ![]() My $0.02 ![]() John |
If you have the room, do it!
__________________ Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3 |
| if you use rails a moving table design will need twice as long rails compared to moving gantry. My 1st router is moving table, my second will be moving gantry, both use linear guides.
__________________ ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ● |
| The Break even point between Moving Gnatry and moving plate depends on your machine structure: For a specified Z axis ( upper point for max distance to x rail) a given Cutting engagement force ( + reactio on Spindle) a given Speed ( acceleration of mass = Force) you need a certain stiffness which in one point belongs to the depth of the gantry support if the required x range would be much more than the effective gantry depth then a moving gatry is the better way. if x range and gantry depth would be equal and you can effort the space it is a cost thing to go for moving plate if there would be shorter travel than gantry depth I would go for moving plate in case of cost and stability but finally this is my opinion and you'll have to make your decision yourself!
__________________ Why reach for speed, when you could have precision instead!!! |
#10
| The common concensus is a moving table needs wide bearing block spacing along the rails while moving gantrys get away with narrower spacing. I'm experimenting with a different design with stationary bearing blocks. From a torsional point of view it has advantages over a moving gantry. It does have a problem with the table tilting fore/aft due to the central placing of the bearing blocks. The plan is to use roller bearings to support the table. The bearings will be mounted to square tubing which will also be part of the base structure and give additional support to the y axis (bridge). The rails are 48", the screw is 38". The square tubing will be much longer, the current pieces are what was handy. It's an experiment. I'll play some more before wasting any metal on it. Hopefully the pictures add some clarity to my word salad
__________________ Anyone who says "It only goes together one way" has no imagination. |
#11
| Cyclestart - I wouldn't 100% agree with you : On a compact built with fixed and loose bearing thread support you would have to calculate : Moving plate over all thread length is ( minimum) _effective x movement +nut length +engagement length for emergency spindle end switches +loose side spindle end length +fixed side spindle end length _________________________________ -> this means that the loose side support has to be lower than the plate so the plate can run over it so you save a little bit less than half of the thread length Moving gantry over all thread length is ( minimum) _effective x movement +gantry depth or nut lenght (the longer dimension of both counts) +engagement length for emergency spindle end switches +loose side spindle end length +fixed side spindle end length _________________________________
#12
| I was working from memory, never a good idea Some tape measure numbers +/- the fractions: The effective travel of the screw is 31", the rails are 47". The cutting length on the x is equal to the screw travel. The 6 rail blocks could be placed further apart but the x travel would be reduced. A longer screw could be used but the 6 rail blocks would need to be placed closer together. It's a very flexible design in that way. Whether it's a good design is another question altogether. It's fun and functional. Pretty easy to slap together. If it's eventually scrapped I get to keep all the pieces.
| Open Team Cheap DIY CNC Moving Gantry Router | pminmo | DIY-CNC Router Table Machines | 94 | 08-19-2007 01:59 PM |
| Moving Table vs Moving Gantry; Dremel vs Router | chuckknigh | DIY-CNC Router Table Machines | 32 | 03-27-2007 08:48 PM |
| Newbie, How you decide Moving Gantry or Table ? | Calico | DIY-CNC Router Table Machines | 5 | 04-02-2005 08:00 PM |
| Moving or fixed Gantry ?? | xairflyer | DIY-CNC Router Table Machines | 4 | 02-21-2005 10:54 AM |
| Moving Gantry Or Moving Table | DDM | DIY-CNC Router Table Machines | 9 | 04-28-2004 10:46 PM |
