Old 11-04-2007, 06:57 PM
wdp67 is on a distinguished road
Dual Vee Wheels
Anybody got any experience building a router using these wheels. Please tell me how it worked out and show some pics if you can.
Walt
Old 11-04-2007, 07:48 PM
ger21's Avatar
This one here used them. Unfortunately, all the pics in the thread are gone.
Ted's Machine Starting at Sq #1
Old 11-04-2007, 11:42 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
http://ww.mechmate.com
Old 11-05-2007, 09:25 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
http://www.cnczone.com/gallery/showphoto.php/photo/114
http://www.cnczone.com/gallery/showphoto.php/photo/232
Old 11-05-2007, 11:18 AM
wcarrothers1 is on a distinguished road
Here are some pics on the 4x8 project
Don't know if these are the type of V wheels you are thinking about how ever I can say they work well on my machine
b.
Old 11-05-2007, 04:47 PM
Yeah those are the ones, what do you guys think of this for x and y made out of MDF and Angle iron.
Old 11-05-2007, 04:58 PM
While I believe the ones I have are dual row bearings I would not consider them lateral contact races. By that I mean loading them sideways the way you are may not exactly be the direction they have the most support. having the load to their shaft is the way they are suposed to ride far as I know. They might have a chart you can figure out what their vertical vs sideways loads are rated at.
I would not do it like that my self.. I'd make them ride as I did.
b.
Old 11-05-2007, 05:00 PM
Also the larger ones like I used are not all that cheep (depending on how lucky you get getting them) so keep in mind they add up (cost wise) quick...
b.
Old 11-05-2007, 07:02 PM
ger21's Avatar
How do you mount a spindle to that?
I do like the horizontal rail idea, though. I may incorporate that for the X rails on the machine I'm designing. Looking at the BWC catalog, it looks like as you widen the rails (from angle to angle), the axial load decreases, if the load is in the center. After some quick math, it looks like as you double the width, the axial load decreases by half. The #2 size rollers are rated at 140lbs axial load.
Based on the formulas I see in the catalog, a 200lb load gantry, with the load centered on the carriage, with the rollers axles at 4" OC (2-5/8" across the points of the angles), would give an axial loading of about 38lbs/wheel. Well below the 140lb rating.
Unfortunately, where the loads are actually coming from during motion is a bit more tricky to figure out, and not so simple. And feel free to check my math. Download the catalog at www.bwc.com
Old 11-05-2007, 07:28 PM
So what would you do different to make it a viable idea? As far as mounting the z I would mount it to the carriage on the y axis.
  #11   Ban this user!
Old 11-05-2007, 07:31 PM
I am not done with the drawing, I was just playing around today and came up with that. The best way to mount the z might be to turn the y on its side and build a torsion box. I am no engineer, Just want to build a nice router and looking for ideas.
Walt
  #12   Ban this user!
Old 11-05-2007, 11:16 PM
I know not the best drawing but how bout something like this? you could use rollers on both the top and front to keep the z from any movement.
Walt
ULS wheels Jim Huston Laser Engraving & Cutting Machines 1 12-18-2006 10:55 PM
Source for v-wheels vid1900 Linear and Rotary Motion 2 11-08-2006 12:32 PM
Dual Vee Wheels Rypper DIY-CNC Router Table Machines 3 10-11-2006 06:36 PM
? about jog wheels mdreitzusa Benchtop Machines 5 05-18-2006 04:49 AM
skateboard wheels for vee wheels... lurch Linear and Rotary Motion 0 10-02-2005 12:10 AM
