Old 11-03-2007, 11:31 AM
drafterman is on a distinguished road
Unhappy rapid speed
Good morning,
I have a question about my rapid speed. I can only get about 20 inches per minute before my motors start to break up or stall. I am using a Xylotex 4 axis kit with 425 oz-in motors and 1/2-10 ACME thread. The motors react like this without any load as well. Every motor reacts the same, but I don't really know how to address the issue. The machine works great, but travel is very, very slow. Perhaps I am expecting too much, but it seems like everyone else has much better speed than I. Please advise.
Old 11-03-2007, 11:41 AM
ger21's Avatar
That's a common problem with the Xylotex. If you have dual shaft motors, one solution is to buy or build a damper to eliminate mid band resonance, which is most likely your problem.
Another option is to switch to 2 start acme screws, 1/2-8 or 1/2-10, which will just about double your speed, but you'll still probably have resonance issues. I've seen a lot of posts saying that those motors can not be spun very fast with the Xylotex, due to resonance issues. The damper should haelp a lot.
http://www.cnczone.com/forums/showth...639#post256639
Old 11-03-2007, 12:22 PM
Thanks, I am going to start making a set of these right now! Is there anything I can do with micro-stepping to help out with the resonance issue?
Old 11-03-2007, 12:31 PM
ger21's Avatar
You can try the different settings, and they may make a difference, but you'll need to try to see if it helps.
Rapid to (# set by Parameter) What's yours? Scott_bob G-Code Programing 8 07-13-2009 08:05 AM
rapid speed contractdesign Bridgeport and Hardinge Mills 6 06-04-2007 10:23 AM
G-Zero by Rapid Output!!!!! tobyaxis General CAM Discussion 0 02-04-2007 11:16 PM
Rapid moves G00 dicksonhof Mach Software (ArtSoft software) 9 11-07-2006 10:21 AM
New Taig, 8 ipm maximum rapid speed? fivaxis Taig Mills & Lathes 5 05-11-2006 09:55 AM
