#13
#14
| The cheapest thing your going to cut metal with is a oxy torch, the good news is you can cnc the torch, & stay low budget. http://www.cnczone.com/forums/showthread.php?t=24187 . Last edited by Switcher; 11-03-2007 at 10:34 AM. |
#16
| Switcher is completely right. there's no sense in building a machine dedicated to cutting steelPLATE by means of milling.Some kind of torch is the way to go wich is a very big plus because a torch cutter will cause a lot less stress and pulling forces to your frame except when rapiding and other fast moves wich means you can save by using smaller motors then when milling and keep your design "lightweight".If you want to use the machine for a long time i wouldn't recommend mdf cause it will deform and all the gasses from the bath underneath your workpiece could eat into it.
__________________ Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol. |
#19
| when cutting with plasma you'll have to change gas/mix ratio's and pressures according to the material at hand to maintain a clean cut When thight tolerance is required finishmachining on a mill/lathe is unbearable for as far as i know plasma torches can't cut with hundredths of an inch precision and my guess would be that the heat will cause some deflection. If looks are all that matter sandblasting polishing or a vibratory polisher would be sufficient. i haven't got any experience with plasma cutting myself and all above i have read here at the zone and interpreted as good as i could.
| New CNC machine build (big pics) | ckm | Vertical Mill, Lathe Project Log | 15 | 04-30-2012 05:49 PM |
| mvaughn's 2nd machine build | mvaughn | CNC Wood Router Project Log | 21 | 01-02-2010 07:53 PM |
| Use the second machine to build the first! | Madclicker | CNC Wood Router Project Log | 160 | 06-26-2007 11:29 PM |
| Buy commercial machine for 6k or build your own? | Menatep | Commercial CNC Wood Routers | 20 | 04-08-2007 09:26 PM |
| Want to build new machine | thuffner3 | CNC Machining Centers | 2 | 02-14-2004 08:47 AM |
