Old 06-06-2004, 07:28 PM
ljoe1969 is on a distinguished road
someone wanna write a program?
would someone write a program that would take a gcode file from "ace converter" to tell the cut time based on the feed rate in the gcode file?
Old 06-06-2004, 07:45 PM
ger21's Avatar
If someone were to do this, it wouldn't be entirely accurate due to acceleration and deceleration. Depending on your machine, it could be off a lot.
Old 06-06-2004, 07:47 PM
turbo cnc gives acceleration lengths and times. the new program if someone were to write it could take this info into account.
Learning to Program CNC Turning Center Farmer G-Code Programing 13 09-12-2005 12:03 AM
parametric programming Karl_T CamSoft Products 21 05-24-2005 02:58 PM
How to cut multiple parts (loop a program) Bird_E Mach Software (ArtSoft software) 6 05-13-2005 03:16 PM
feeds and speeds program Kees Soeters General Metalwork Discussion 3 05-12-2005 12:32 PM
A few honest questions HuFlungDung CamSoft Products 8 06-15-2004 06:24 PM
