Old 10-30-2007, 04:16 PM
Ferrari2007 is on a distinguished road
Rookie Question...3 axis vs 4 axis controller
I am considering building my first CNC machine and have seen several designs that use 2 motors on the X Axis. I would like to use this design approach. My question is are these two motors generally wired in parallel using a 3 axis controller, or is a 4 axis controller used and it treated as a fourth axis and programmed the same as the third axis?
Old 10-30-2007, 06:37 PM
ger21's Avatar
Use a 4 axis drive, and let the control software slave the second X motor to the first. Mach3 has this capability.
Old 10-30-2007, 09:22 PM
Gerry,
Thank you for the information, I will go the 4 axis route.
Thanks again
Kevin
Old 09-13-2009, 09:04 PM
skyburt is on a distinguished road
I have just built a gantry style machine, I run the "y' axis with 2 motors. You slave the "A" axis motor off the "Y" .This is done in the Mach3 config settings.
enjoy
Burt
4 axis controller pump Australia, New Zealand Club house 3 08-11-2007 12:16 AM
Need Help With 3 Axis Controller jeffg Machines running Mach Software 0 03-29-2007 04:05 PM
4 axis controller for 3 axis machine? tybrenis CNCzone Club House 8 01-19-2007 10:12 PM
3 axis stepper motor controller board - question Yellowbeard Stepper Motors and Drives 17 04-06-2005 11:02 PM
