Old 10-26-2007, 07:04 PM
eloid is on a distinguished road
rack and pinion question
is there backlash in rack and pinion and if so how to control it?
Old 10-26-2007, 07:44 PM
number of teth per gear recommendaton
for rack and pinion machines which use either a 3.6:1 or 7.2:1 gearbox
how many teeth per gears is recommended.
As a observation on commerical machines ,,,,use larger number of teeth?...
i concluding 30-tooth gear gives smoother operation and much longer spur-gear life. For a non-geared motor, use 20-tooth spur gears?.
Old 10-27-2007, 11:17 AM
rustamd is on a distinguished road
In my opinion you need spur gear to be big enough to have at least 3 teeth engaged at all times, the more teeth are engaged, the less the gear would want to jump out of rack(with proper load on it of caourse)
Old 10-28-2007, 09:22 AM
jcc3inc is on a distinguished road
Backlash
Sir,
For rack and pinion systems there are several considerations:
1. Use 20 degree rack and pinions
2. While I prefer 24 dp (diametral pitch), 20 dp rack is readily available from www.stdsteel.com/gear.htm
3. Matching piions can be had from Boston Gear, Martin Sprocket and others. Use AT LEAST 18 teeth on the pinion; we used around 30 teeth for better number of teeth in contact
4. Spring load the pinion into the rack with a force of (.37 x the max drive force expected).
For example, if you expect 50# force, the spring should push the pinion into the rack with 18# of force.
5. Set your pivoting point for the above mechanism so that it falls on the pitch line of the rack. This will result in equal pinion-to-rack engagement forces for driving forward or backward.
The gear reduction you choose depends upon whether you use servomotors or steppers, the number of microsteps you use, the force required, the system mass, and the expected max cutting force requiored for your application.
Regards,
Jack C.
Old 10-29-2007, 09:30 AM
edco78 is on a distinguished road
rack & pinion
Take a look at this site: http://www.nexengroup.com/nexen/prod...duct?pn=966600
Old 10-29-2007, 12:36 PM
thats one expensive option
Old 10-29-2007, 07:27 PM
harryn is on a distinguished road
jcc3inc - thank you for that very clear summary. It certainly helped me.
Rack and Pinion for x, y axis question ??? zeoncomp CNC Plasma and Waterjet Machines 2 09-22-2007 09:19 AM
rack and pinion luther DIY-CNC Router Table Machines 8 07-06-2007 10:53 PM
Shopbot Rack&Pinion question IQChallenged DIY-CNC Router Table Machines 1 07-12-2006 08:41 AM
Rack & pinion coolman DIY-CNC Router Table Machines 6 05-07-2006 04:14 PM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
