Old 10-25-2007, 06:08 AM
teamtexas's Avatar
teamtexas is on a distinguished road
How do I check parallel port settings?
I'm trying to make sure my laptop parallel port is set right. I have a Compaq laptop and it's running Windows 98. Anyone know how to get to those setting points?
Old 10-25-2007, 06:18 AM
bluejay_ca is on a distinguished road
control panel,system,device manager
Old 10-25-2007, 04:19 PM
teamtexas's Avatar
Wow...it sound so easy when you put it like that! Thanks Dan
C++, Win XP, Parallel Port Zumba Coding 7 03-29-2012 01:12 PM
port and pin settings not saved? Block16 Mach Mill 2 09-26-2007 08:13 AM
2nd PCI Parallel Port sunmix Mach Software (ArtSoft software) 8 11-22-2006 02:17 PM
MACH 1.90.065 "Nedd port and pin settings over60 Mach Mill 8 08-07-2006 07:32 PM
parallel port settings/output signals TMaster Xylotex 6 04-23-2006 11:16 PM
