Old 06-01-2004, 02:03 AM
bsmith is on a distinguished road
Mastercam Router Questions
Does anyone know the approximate pricing for the Mastercam router series of products (entry, reg. and pro)? From what I heard, Mastercam in general may be out of my limited price range. I'm looking for a CNC router package that is set up for large sheets (e.g. 4x8') and that will preferably do tabs and nesting.
Besides the pricing question, I'm also wondering if any software out there supports round-over and chamfer bit geometry. For instance, running a specified size round-over bit along some of the edges of parts. Any help would be appreciated...
Old 06-01-2004, 07:00 AM
ger21's Avatar
I'm going to guess around $10,000 and up. You should contact a distributor to be sure. You might want to look at CadCODE, http://www.cadcode.com. It does nesting. Also look at AlphaCAM.
Old 06-02-2004, 04:49 AM
Thanks for the suggestions. I'll do a little research on the packages you mentioned. BTW, I found out about the price levels for the Mastercam router series:
Router Entry: $3000
Router: $5000
Router Pro: $14000
Old 06-02-2004, 06:30 PM
DDM DDM is offline
DDM is on a distinguished road
Ok this is a little off topic but what exactly is nesting? I hear it here and there but I'm not quite sure what it means
Carl
Old 06-02-2004, 08:54 PM
ger21's Avatar
Nesting is taking a bunch of parts of different sizes and shapes, and placing tham on your sheet stock in the best possible configuration to best utilize the stock.
Old 06-02-2004, 09:18 PM
DDM DDM is offline
Ok, I understand, I've heard of the process before but I didn't know what it was called. I may have to keep this in mind if I apply for a position at one of the boat shops.
Carl
MasterCam lathe Questions mefull Mastercam 12 09-16-2006 09:38 PM
Questions about JGRO Router ignatz JGRO Router Table Design 4 06-02-2005 10:27 AM
Questions - Micro CNC router? DarkWolf DIY-CNC Router Table Machines 36 10-22-2004 09:24 AM
Newbie Question MasterCAM Mill for Router Sanghera Mastercam 3 04-28-2004 10:41 AM
Wood Router Plans questions CNCadmin DIY-CNC Router Table Machines 23 03-23-2004 11:09 PM
