Old 10-17-2007, 08:14 PM
eloid is on a distinguished road
Convert motor torque into linear force:
I found this formula to estimate linear force developed using a screw / motor combination:
1. Convert ballscrew lead to equivalent pully radius:
example:
Lead =0.200
0.200 / (2pi) = 0.200 / 6.283 = 0.0318" (equliv. radius pully)
2. Convert motor torque into linear force:
example:
Torque = 100 Oz.-In.
100oz-in / .0318 in = 3144 oz. (linear force)
3144 / 16 = 196 lb (linear force)
196 * 0.8 (efficency for ballscrew) = 157 lb linear force.
If this formula is correct, a 100oz-in motor and a 0.200 screw can push 157 pounds force."
so if your not useing a ball screw do u just use thread per inch instead of that .2 use in the above eg?
how does this change if u plan to use 4:1 gear ratio?
Old 10-17-2007, 09:26 PM
NC Cams is on a distinguished road
You forgot loss from coefficient of friciton - probably negligible in a ball screw.
A 4:1 gear reduction will increase the force driveable by the motor a factor of ~4 times MORE with a speed decrease of ~25%
Old 10-17-2007, 09:33 PM
Al_The_Man's Avatar
There is a mention of ballscrew efficiency (*.8)??
Fanuc 10/20M Convert to Torque/Current mode mch Fanuc 2 04-18-2007 09:37 PM
Rotary to linear torque converter. flakker Mechanical Calculations/Engineering Design 0 03-21-2007 07:55 AM
Cam- gear motor - force applied to follower? Chris D Mechanical Calculations/Engineering Design 3 05-05-2006 11:41 AM
Convert Drill Motor to Servo - Possible? creative_mind General Electronics Discussion 4 02-16-2004 10:15 PM
Linear Motion Force Debate CNC Brute DIY-CNC Router Table Machines 4 11-22-2003 07:11 PM
