#13
| Ok mate, but I do get the impression! Anyhow, the holes can be cut accurately, but you do need the tilting table on the drill press, otherwise you could make a 45 degree jig from wood. The most difficult part is getting the position for the bearings in the first place! A bit of trial and error here for me, the first part I made had to be scrapped because the bearings were too far back, but the second is good. I have one bearing that is not tight against the rod, but a small shim washer should take up. Of course I should mention that I made the body and bearings first, then measured for the rods, rather than having the rods in place, then measuring for the bearings - that would have been impossible! |
#14
| I just thought of an idea. Instead of worrying about getting the bearings lined up, Why could'nt you turn down a bolt on a lathe so that the shaft is off center from the thread. ( this bolt holds the bearing down)The bolt would act like a cam. Turn the bolt till the bearings hit just right and tighten the nut down. Hmmm . I love thinking about building stuff..
__________________ My little piece of the web! http://users.adelphia.net/~wjdupont |
| Low cost idea for machine ways. Thoughts? | jstuedle | DIY-CNC Router Table Machines | 11 | 06-28-2006 07:05 PM |
| Low cost machining centre retrofit | motordude | General Metal Working Machines | 2 | 01-07-2005 01:32 AM |
| Need a low cost 4 amp, 48 volt, stepper drive | Mini Miller | Stepper Motors and Drives | 19 | 12-15-2004 01:29 PM |
| Active High/Active Low | Sanghera | General Electronics Discussion | 21 | 11-06-2004 08:47 PM |
| Anyone selling low cost wipers for ballnuts? | sendkeys | General Metal Working Machines | 0 | 07-16-2004 07:43 PM |
