Old 10-15-2007, 10:43 PM
lm6769 is on a distinguished road
Question Newbie needs help building CNC
I want to build a small CNC I have seen some of the machines built on this site and want to do the same. I just want to create my first small CNC, nothing crazy, I want a 3 axis though. Maybe someone can help lead me in the right direction. I do have knowledge of CNC though, I work for a company where I program and operate a 6'x12' komo 3 axis CNC I use autocad and microvellum to program. We are a cabinet shop so majority of material is wood. please help me create a fun project CNC.
Old 10-16-2007, 11:02 PM
rustamd is on a distinguished road
biggest help for you would be to spend few weeks reading the forums, you did come to right place and it will help you, but you need to donate some time to your project and go through others build logs, see what problems people ran into etc. Good luck
Old 10-23-2007, 09:59 AM
ahren's Avatar
ahren is on a distinguished road
Hi lm. There are good plans available from Joe for an inexpensive system -- see thje subsection on Joe's routers in the DIY section. I'm also working on plans for a system that I will be giving away that uses parts from my website, www.cncrouterparts.com.
If you have access to a machine at work, you might be able to cut some really great parts for your system and save on cost. You could start with a nice torsion box table for a flat, rigid surface.
building a cnc/newbie Mr. midnight DIY-CNC Router Table Machines 12 06-21-2007 08:55 PM
Newbie to CNC Engraving / Milling machines new help building from scratch tera_bit DIY-CNC Router Table Machines 3 03-23-2006 07:39 PM
Building my first one, need HELP! TopCat General Electronics Discussion 11 01-19-2006 08:59 PM
Should I consider building a cnc or just buy one? johnt CNC Plasma and Waterjet Machines 18 03-28-2005 11:19 AM
building my own bean7795 Benchtop Machines 6 06-22-2004 10:24 AM
