Old 05-26-2004, 08:41 AM
ddgman2001 is on a distinguished road
Best linear bearing system for a dusty router
What would be the best linear bearing system for wood routers regardless of cost?
My machine uses V-wheels and track which work OK, but need frequent cleaning.
I can see the recirculating ball style gumming up with sawdust pretty quickly.
Old 05-26-2004, 09:06 AM
Cold Fusion is on a distinguished road
I've heard good things about the Frelon one piece bearings in dusty conditions.
Proud owner of a Series II Bridgeport.
Old 05-26-2004, 01:05 PM
buscht's Avatar
buscht is on a distinguished road
Look at the industrial CNC routers costing over $100,000. They almost all use THK linear bearings. They use a wiper to clear the rail of dust. You can get something similar for your Vee rollers.
Old 05-28-2004, 06:41 PM
maurizio is on a distinguished road
it is possible to eliminate most of the dust by installing accordion tipe guards
if you go to the thk site or any company selling linear guides you can find covers tha wil cover the all thing.
the only problem is that you might loose some of the travel
Old 05-28-2004, 09:51 PM
ger21's Avatar
And they cost a fortune. $20-$25/ft
Old 05-29-2004, 06:33 AM
strat's Avatar
strat is on a distinguished road
i wrapped pipe cleaners around the rail i use the frelon slides and it works fine
Old 05-29-2004, 07:19 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
I heard of a system where there is an air jet attached to the bearings and constantly blows the dust off.
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
gas pipe & linear bearing dimensions relationship zoltan Linear and Rotary Motion 6 06-13-2005 03:12 PM
a cheap linear bearing mocnc DIY-CNC Router Table Machines 8 03-26-2005 04:52 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
Your advice please on this Linear Rail system Moondog DIY-CNC Router Table Machines 9 10-13-2004 08:14 AM
