Old 10-04-2007, 04:51 PM
planekrazie's Avatar
planekrazie is on a distinguished road
Quick question about gantry width..
Just a quick question about a new machine I am gonna build. What would be a good width ( to reduce racking ) for the gantry? I am talking about how far to space the bearings for the gantry to ride on. Is 6" too little?
I am gonna try to build the cnc about 36"x48" cut area.
Steve
Old 10-04-2007, 05:13 PM
wcarrothers1 is on a distinguished road
all depends on the drive, 2 screws, one center screw, rack/pinion on each side ect..
Typicaly you need less bearing space (I'd say) for 2 screws vs center screw.
I think the vbearings I have setup are only maybe 9" apart but I have racks/and pinion driving on either side connected by a shaft that keep it from racking..hehe
b.
Old 10-04-2007, 05:24 PM
I think I am gonna go with the screw in the center. So does 8 inches sound good for bearing spaceing?
Steve
Old 10-04-2007, 06:40 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
If you use a TDK style rail with recirculating ball trucks, or round supported linear rails and ball bushings, or even roller skate bearings on a stationary rail, one screw in the middle will work fine. The distance between bearing slides is not an issue, but the parallel and horizontal alignment are. Any gantry tracking loosely or on an improperly aligned slide, will bind jump and chatter doing heavy cuts.
From the side view of the gantry, the front and rear bearings should be equal to half the height of the gantry. Making this too narrow will reduce the strength at the top of the gantry, or when the cutter is at max height. Think of it as a triangle, wider at the base, makes the top very stable and strong.
For a wide distance between gantry sides, I would suggest a dual set of round linear rails set parallel to each side of the gantry end plates. this set of four slides will allow for an extremely rigid and inexpensive tracking system. The y-axis should also be a dual slide, to ensure squareness and rigidity.
My two cents.
Widgit
Old 10-04-2007, 10:53 PM
This is a great Tip. Thanks widgit.
Steve
My two cents.
Widgit
Old 10-05-2007, 01:45 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Hey Steve - I used 8020 and the cut size on the System2 would be that if my linear rails were long enough! The spacing on my Bridge (vice Gantry) is pretty close to 8 - 10 inches. I've experienced no racking of the bridge and only drive from one side of the X axis (not both).
Any help there? See Pics in my gallery.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
New here, quick question 2T on TC-2 RonRoy2004 G-Code Programing 2 11-06-2005 09:16 PM
Quick Tig Question Edster Welding, Brazing, Soldering, Sealing 5 08-15-2005 08:19 PM
really quick question: bigal General Electronics Discussion 1 06-21-2005 07:39 PM
A quick question? Bartman Solidworks 4 05-30-2005 09:24 PM
Quick V18 Question Edster BobCad-Cam 3 12-13-2004 09:53 AM
