Old 05-20-2004, 01:07 PM
Photon is on a distinguished road
Bearing in MDF
What's a good way to hold this bearing in place?
Thought about glue, but I guess that will prevent me from replacing the bearing when needed.
Old 05-20-2004, 01:09 PM
pminmo's Avatar
pminmo is on a distinguished road
How about a small piece of dowel rod the same diameter as the hole with an appropriate sized hole in the middle?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 05-20-2004, 01:35 PM
It may work.
What would hold the dowel ring (dowel rod slice with a hole in the middle) in place?
Should it be made to fit the thickness of the MDF and then held in place by some piece of wood bolted to the MDF board?
Is there a more elegant solution?
Old 05-20-2004, 01:36 PM
kong is on a distinguished road
Or if you can move the bearing, you could make a metal plate to lock the bearing in place, like over here:
http://www.buildyouridea.com/cnc/tk-...6/phase_6.html
Old 05-20-2004, 02:04 PM
HuFlungDung's Avatar
Moderator
You could look for some bearing flangettes. This is a pair of stamped metal pieces designed to hold a spherically shaped OD bearing. This is very common on agricultural equipment. Cheap too...not as cheap as a hole in a piece of MDF, though
To mount these, you simple drill a couple of bolt holes for mounting bolts that go through the flangettes. It is kind of a self aligning face mount bearing fixture.
Old 05-20-2004, 02:18 PM
Hobbiest is on a distinguished road
If you are using MDF for your frame, bore into it with a forstner bit the correct OD of the bearing. If not using MDF, either bore in to your material a suitable amount, or make up a mounting block out of MDF or UHMW. Get a fender washer with a suitable hole size so that it won't constrict the motion of the bearing. Drill two holes on the flange, and secure it to the MDF base with screws.
Stop talking about it and do it already!!!!!
Old 05-20-2004, 04:18 PM
pminmo's Avatar
Use a fender washer (big washer available at hardware stores)and a glue the dowel to the washer. See pic.
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Caution building with MDF DJ Morrow Safety Zone 16 01-30-2007 09:28 AM
Torsion box and Skate bearing thought spalm Linear and Rotary Motion 0 06-03-2005 03:19 PM
a cheap linear bearing mocnc DIY-CNC Router Table Machines 8 03-26-2005 04:52 PM
MDF Machine - Cut Aluminum? JavaDog DIY-CNC Router Table Machines 7 11-10-2004 01:05 PM
