hello cnczone i have a question sorry if my terms are rough ! im now buying the needed parts to build my cnc mill . i have picked up a thk linear actuator for my z axis , along with thk lm slide rails . im having a hard time finding thk actuators with the stroke lenghts i need 24"and 30" or something close. i will be using thk lm slide rails for all axis . do i really need actuators or will just the lead/ball screws do fine .the reason i was leaning towards the thk acutuators was for the ease of install . sorry if the above doesnt make sense its late . thanks for any info cheers mike |
Hi, I made my cnc mill using THK KR33 LM series, very easy to mount and though second hand actuator but backlash should be less than 10 micron. I only have a 10 micron resolution dial gauge. Definelty worth it not only easy of mounting but also for straightness and stiffness. |
Hi, I got the complete THK KR33 module from a scarp dealer in my country, Singapore. Mine is about 450mm stroke with a 6mm pitch. There is no dovetail component. They are based on THK caged bearing system. The scarp dealer has lots of different length available. Let me know of your requirement and I might be able to help. |
[QUOTE=mjs79;346192]hello cnczone i have a question sorry if my terms are rough ! im now buying the needed parts to build my cnc mill . i have picked up a thk linear actuator for my z axis , along with thk lm slide rails . im having a hard time finding thk actuators with the stroke lenghts i need 24"and 30" or something close. i will be using thk lm slide rails for all axis . do i really need actuators or will just the lead/ball screws do fine .the reason i was leaning towards the thk acutuators was for the ease of install . sorry if the above doesnt make sense its late . thanks for any info cheers mike [You don't need to use actuators, but I found they make things easier. It's possible to mount ballscrews, bearings, motors, and slides accurately on a straight, stiff piece of metal, and build a platform that slides on them to attach to, but if you get an actuator that's all done for you. I built a machine from similar units myself; I posted something about it in the DIY router section (Deep Z 4-axis machine - no replies yet). I might have some more NSK actuators that would work for you; let me know what lengths you need. Mine have Tamagawa servo motors and steep-pitch screws, but they can be driven with stepper motors if you make adapter plates for them.] Andrew Werby www.computersculpture.com |
| Ball screw or Acme lead screws | bgolash | Polls | 18 | 05-10-2010 02:44 AM |
| Where to buy lead screws? | eldruida | Linear and Rotary Motion | 1 | 09-24-2007 06:33 AM |
| 1 or 2 lead screws | spoolin_20b | DIY-CNC Router Table Machines | 6 | 03-22-2007 04:50 PM |
| Ball screws, Acme screws, threaded rod | DJ Morrow | DIY-CNC Router Table Machines | 11 | 03-22-2007 12:39 PM |
| CNC Router (Ball Sliders and Lead Screws) | JB Laser Tech | Linear and Rotary Motion | 0 | 12-03-2006 05:45 PM |
