Old 09-21-2007, 05:28 AM
Kieron is on a distinguished road
Spindle motor question
Hi everyone, this is my 1st post to these boards. Been lurking here for a while reading and learning. So much info here its amazing.
Anyways to the point. Im going to make a small spindle based on the ideas of some people here and use an er16 collet chuck for starters. The trouble is i dont know a great deal about electronics, just the basics.
I was going to use this motor from surplus center Item# 10-1783-A. Its the 2.5hp one. But what exactly would i need to power it ? The DC motor controllers they stock state they do up to 2hp motors with extra heatsinks and such. But would they work with this motor ? If anyone could help me out and show me what i would need to order to use this motor it would be greatly appreciated.
Oh yeah im from Australia to so i need something that works with 240v.
Kieron
Old 09-21-2007, 06:04 PM
andy_ck87028 is on a distinguished road
Keiron
A link is needed to identify the motor. I could not find via google alone.
Andy
Drat, imperfection has finally stopped working!!
Old 09-21-2007, 06:43 PM
Al_The_Man's Avatar
This is the link http://www.surpluscenter.com/item.as...item=10-1783-A
These are the low man on the totem pole as far as DC spindle motors are concerned, to run them on 240v, look for KB SCR drives or relabeled Baldor and others on ebay.
You can set these DC drives for 90vdc motor.
The surplus centre often have some higher quality motors, IIRC some are rated at higher voltage.
Servo motor used as spindle motor? fatal-exception General Metal Working Machines 6 09-14-2007 02:55 AM
more rpms for spindle motor and spindle bob1112 Mechanical Calculations/Engineering Design 33 02-10-2007 01:01 PM
Spindle Motor for my cnc? Cooper Open Source CNC Machine Designs 1 12-10-2006 01:11 PM
DC Spindle motor Phooey Bridgeport and Hardinge Mills 9 09-26-2005 12:02 AM
Spindle for metal and wood. Motor size question bgolash DIY-CNC Router Table Machines 2 05-20-2005 11:15 AM
