Old 09-09-2007, 11:33 AM
DICKEYBIRD is on a distinguished road
Upgrade from drawer slide suggestions please.
Good morning gentlemen. I have attached a few pics of my little CNC router table I built some years ago from Dan Mauch's article in Nuts & Volts magazine. It has served my balsa & ply cutting needs pretty well so far.
Over the past 3 yrs., I have obtained a lathe, mill and other metalworking tools. I'm not ready to convert my X-3 mill to CNC just yet but was thinking about using my machine tools to modify my router to reduce the flexing inherent in the drawer slide setup. Does anyone have any suggestions for replacing the drawer slides with something else that would reduce the flex but would fit in the same footprint and wouldn't require starting over with a completely new machine?
Many thanks for any suggestions.
Name:	Robert L sm.jpg‎
ID:	43354   Click image for larger version
ID:	43355   Click image for larger version
Old 09-09-2007, 12:56 PM
Oldmanandhistoy is on a distinguished road
If cost is not an issue then I would upgrade to supported round linear rails and linear bearings to match. Other possibility would be to use oil impregnated bushings with the same rails (cheaper) unsupported.
John
Old 09-09-2007, 01:02 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Try V-rollers.
Old 09-09-2007, 05:16 PM
Regnar's Avatar
Regnar is on a distinguished road
instead of relying on the slides for support you could always attach the slides to 80/20 and keep pretty much the same setup. You could probably use there 1515 which comes in I think to a dollar a foot.
Old 09-10-2007, 10:34 AM
TSJ TSJ is offline
TSJ is on a distinguished road
A simple solution would be to get a plate of UHMW the size of your base. Drawer slides have holes for mounting, cut a piece of the UHMW the height required screw it to the slide and let it slide around on the plate removing any warping from the slide.
Old 09-11-2007, 08:54 AM
Thanks guys for your input! I've been looking around on the 'bay and it looks like 12mm linear bearings are plentiful and cheap. Example: http://cgi.ebay.com/16-LM12UU-Linear...QQcmdZViewItem
So I guess I'm going to modify my machine based on them. I was originally thinking of using the supported shaft system with the "C" shaped linear bearings but they don't seem to be as plentiful (cheap!) as the round ones. Since my machine only has 12" X/Y travel, wouldn't the 12mm shafts be OK as far as flex goes?
Also, does any one have a link to a build thread for a similar type machine using round shafts and linear bearings?
Old 09-11-2007, 05:42 PM
IMHO if you will be only cutting balsa and ply (used for RC?) and small diameter cutters then 12mm unsupported rails will be fine. Do a search for a programme call “beamboy” it’s free and you can do the math very easily on there just to be sure.
As for a similar design there should be a few I would have thought in the “CNC Wood Router Project Log “ forum they will just require searching out.
Best of luck,
John
Drawer slide design mikeschn Open Source CNC Machine Designs 56 10-31-2009 11:28 PM
Plans for a drawer slide router dan dimock DIY-CNC Router Table Machines 0 12-15-2006 07:58 AM
My First CNC Machine (Drawer Slide Design EidenC Open Source CNC Machine Designs 5 01-04-2006 11:36 AM
Drawer Runners nakchak DIY-CNC Router Table Machines 5 02-13-2005 01:35 PM
