Old 09-08-2007, 01:33 PM
tager_rot's Avatar
tager_rot is on a distinguished road
I built My CNC From David Steels Plans Now I need Feedrate help please
I'm not sure if this is the right forum for this thread so sorry to the mod. if it is not...
I Made My CNC From David Steels Plans and now I need some help with the feed rate.
I upped the size of my router to a 2-1/4 HP PORTER CABLE 892 ROUTER. After hours of searching I now know the chipload formula and other chipload details, but I still don't understand how it applies to my CNC.
What I am wanting to know the most is how to figure the depth of each pass and the feed rate relative to my HP and RPM.
As I said before I have a veritable speed (10,000 23,000 RPM) 2-1/4 HP Porter Cable Router.
I'm am looking to do wood, plastic, HDU and possibly Aluminum.
I have done many little projects and signs with this table already, I keep breaking bits and burning them up at times.
Also the top IPM I can get out of this table is only 35 IPM.
Thank you for any help you may be able to provide.
Justin!!!
TagersGraphics.Com
If your to busy, Your not charging enough!
Old 09-08-2007, 03:49 PM
ger21's Avatar
Bit's usually break from getting too hot and dull. The problem is that the machine is too slow. A lot of 1/4" woodworking bits (spiral) recommend a chip load of around .005. A 2 flute tool at 10,000 rpm will require 100 ipm. A 1/4" spiral bit is easily capable of cutting 300ipm or more.
At 35ipm, your best bet would be to use 1 flute bits, which work better at slower speeds. As for depth of cut, quality will suffer as you cut deeper. Use the tool diameter for depth of cut, but you can go deeper, or shallower, depending on the quality of cut and your machines abilities.
Old 09-08-2007, 10:49 PM
tager_rot's Avatar
where and how does the HP come into play?
TagersGraphics.Com
Old 09-09-2007, 10:37 AM
grahamshere is on a distinguished road
I would say speed of machine< material and depth. you would need more hp to cut 100 ips on say maple at say 1/4" deep cuts . My little ports cable trimmer will bog down some cutting cedar at 1/4" deep cut, It will cut it but the first cut it slows down a bit, after that its ok. Graham
Old 09-09-2007, 12:52 PM
tager_rot's Avatar
Are there any known formulas for table in referance to hp and feed rates???
TagersGraphics.Com
Old 09-09-2007, 01:45 PM
ger21's Avatar
The only time HP comes into play is if you don't have enough. It it starts to slow down, then you'll need to lower your feed rate.
Old 09-09-2007, 01:52 PM
tager_rot's Avatar
Gerry,
Where would I be without you man....
Even on a sunday afternoon I get all the info I need... How many times are you gunna bail me out???
You are the man.... Many thanks!!!
Justin!!!
TagersGraphics.Com
Has Anyone Built From David Steels Sosylva Plans? diarmaid DIY-CNC Router Table Machines 678 06-25-2010 11:31 PM
Machining Hard steels at 1400 SFM? Also, plunging question. facegarden General Metalwork Discussion 23 10-17-2007 01:35 PM
Has anyone used the home built wire edm plans? ariel 1 CNC Plasma and Waterjet Machines 0 03-24-2007 04:57 PM
Spark Testing Steels Barry_ward General Metalwork Discussion 0 01-25-2007 11:19 AM
European Parts suppliers for David Steels solsylva tables Drakkn DIY-CNC Router Table Machines 6 01-17-2007 12:42 PM
