Old 08-31-2007, 09:51 PM
skydemon is on a distinguished road
need affortable antibacklash screw setup 60 inches long
Hi im looking for a affortable antibacklash ballscrew or acme screw setup with around 57 inches of travel. Anyone know where i can find this without alot of whipping.
Old 09-04-2007, 07:42 PM
DonW is on a distinguished road
Affordable?
Define "affordable"...
You can get a reasonable price at homeshopcnc.com. In fact, I need to get the same basic size. My X axis linear rails are about 57", and add to that another 3" of 8020, that puts my ballscrew in the same neighborhood. I just have to figure out the machining for bearings, nuts, and the shaft to couple with the NEMA 34 motors.
Good luck with your project!
Old 09-04-2007, 09:36 PM
SORCHEROR is on a distinguished road
have you considered rotating the nut instead of the screw,no screw whip if you rotate the nut,just a thought,what size motors?and how high of a rapid you looking for?
steve
Choosing a drive screw and motor for a long axis? CnoEvil DIY-CNC Router Table Machines 91 01-08-2007 05:40 PM
my long new machine setup . suggestions please max_imum2000 CNC Machining Centers 0 12-29-2006 12:04 PM
Need Source: MIC 6 Alum Plate, 100+ inches Long dneisler CNCzone Club House 1 12-06-2006 03:40 PM
Long Lead screw support xyz100 Linear and Rotary Motion 21 11-21-2006 10:28 PM
Scaling Units/Inches for Mach2 and MaxNC setup EPM Mach Software (ArtSoft software) 6 08-29-2006 03:28 PM
