Old 08-31-2007, 07:44 PM
studysession is on a distinguished road
Linear Bearing question
Hi -
I have 1" round cold rolled steel rod. Would this be the correct bearing to use with it?
http://www.use-enco.com/CGI/INSRIT?P...PMPXNO=8915426
This one looks nicer but more expensive. WOW!@ What a price tag.
http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=951061
Not sure what to use and Looking for something inexepensive. Thanks
Please check out my CNC blog
http://cncinside.com
Old 08-31-2007, 09:14 PM
Regnar's Avatar
Regnar is on a distinguished road
for the price of the nice looking ones you could get the whole system here http://www.vxb.com/page/bearings/PROD/LM/Kit7429. On another note are you sure that you 1 inch cold rolled steel is actually 1 inch if it is it should work.
Old 09-01-2007, 07:08 AM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
The Rod needs to be hard or the bearings will dig into the surface, from the options the vxb kit would be the best choice, I use them myself.
Old 09-01-2007, 07:16 AM
Thanks for the replies - I already have the 1" round cold rolled steel rods. Just need a couple of sets of bearings. Trying to make as affordable as possible.
The ones on VBX are 20mm not 1". Can't find ones on VBX that are 1".
Thanks -
Old 09-01-2007, 10:19 AM
ger21's Avatar
If you use ball bearings on the CRS, it'll be ruined in a very short time, as the previous poster mentioned.
Old 09-09-2007, 11:01 PM
yukonho is on a distinguished road
Like Ger said, you can not use linear bearings on cold rolled steel.
If you really want to use the CRS, you will have to come up with a skate bearing or v groove bearing type of set-up.
The other, probably best, option is VXB.
co
Old 09-09-2007, 11:40 PM
DSL PWR is on a distinguished road
For some cheaper hardened shafting find a place that sells induction hardened shafting, it comes plain ground and chromed. When I phoned Team Tube I could get 3/4" hardened/chromed for close to the same price as 19mm hardened shaft from vbx. This stuff is normally used for hydralic cylinder rods.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Linear bearing help please. Oldmanandhistoy Linear and Rotary Motion 16 02-07-2007 12:00 PM
What is this? Linear bearing? xyz100 DIY-CNC Router Table Machines 3 07-26-2006 12:55 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
What is a linear bearing ? ynneb FAQ of CNC Machine building 0 08-16-2004 09:34 PM
Linear Bearing tekno DIY-CNC Router Table Machines 6 06-29-2004 03:55 PM
