Old 08-30-2007, 10:48 PM
salvaCNC is on a distinguished road
help needed removing stepper gears
I bought 3 used steppers for my first CNC project. However, they all came with either metal or plastic gears attached to them. I've tried pulling them out without any luck and I do not want to break my steppers.
Is there a mini gear puller/remover or is there a gadget described in this forum on how to do it?
Thanks all for the help.
Old 08-31-2007, 12:45 AM
audin is on a distinguished road
I have successfully removed the brass gears from some steppers by gripping the gears in a vise and tapping on the shaft of the motor using a punch and hammer. Another option i have thought about is cutting into the gears using a hacksaw blade and then splitting them off with a cold chisel.
Old 08-31-2007, 05:17 AM
CarveOne is on a distinguished road
Find a local hobby shop that sells parts and supplies for R/C cars and 4wd trucks. They sell, or can get for you, a small gear puller. With a little effort and some hand tools you can make one relatively easily.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Stepper motors needed timeout555 Europe Club House 4 05-21-2007 10:23 AM
Help needed with stepper motors timeout555 Stepper Motors and Drives 24 04-18-2007 04:21 AM
help needed with stepper motors dream4x4 Stepper Motors and Drives 1 01-29-2006 12:37 AM
Removing nut off ballscrew, I've never seen anything like it geohot Linear and Rotary Motion 7 12-23-2005 09:53 PM
Removing the armature ? Ken_Shea Servo Drives 3 10-10-2005 02:40 PM
