Old 08-25-2007, 06:00 PM
*Registered*
VSNT is on a distinguished road
Gearing ????
im maxing out at 9-10ipm (jogging) and would like to get a heck of a lot more its just way to slow for a 3'x5' machine. Any sugestions im looking into belt drives and pully but cant seem to find anything worth buying???? PLEEEZZZ all sugestions apreciated
Old 08-25-2007, 06:28 PM
Mickster is on a distinguished road
Gearing....or, maybe not.
Hi VSNT,
a belt/pulley setup may not be the answer to your problem...
For a more accurate answer before you start throwing money at your machine, listing your current setup would help greatly.
PSU voltage & amperage?
Motor config (Uni-polar, Bi-polar, series/parallel) ?
Motor voltage ?
Motor torque (Oz/In or Nm) ?
Driver config (Amperage settings, Full/Half/Micro-stepping...) ?
Leadscrew type & pitch (ACME, allthread US/Metric etc) ?
Software setup (Mach, TurboCNC etc. motor tuning settings) ?
All of these factors need to be taken into consideration to get the most out of your machine. Maybe your current settings are not optimized at the moment and this is what is producing low speeds.
I am by no means the right person to offer you advice, as I'm still wearing my L-Plates, but the above info is necessary for those experienced members on the forum, in order for you to tune your machine to it's fullest capacity.
HTH,
Mick
Old 08-25-2007, 06:53 PM
*Registered*
I just tested the motor speed and im maxing out at about 120+- rpm, im using keling 4030 drivers, with there KL23H286-20-8B, 425 oz-in steppers, something wrong ??????
Old 08-25-2007, 08:18 PM
ger21's Avatar
How do you have them wired (bipolar or series?) What voltage are you running them at? For best performance, those motors should be run Bipolar parallel at 70-80V. You'd need better drives for that though.
Old 08-30-2007, 10:56 AM
*Registered*
ok uped to 55v @ 3A and now im getting a max of about 15ipm before i realy start losing steps?????
Old 08-30-2007, 12:30 PM
ger21's Avatar
What type of screws are you using?
Old 08-30-2007, 12:42 PM
*Registered*
was using Kerk Motion 8000's @ 42% and now im using acme 1/2-10's
Old 08-30-2007, 01:24 PM
fireballcnc's Avatar
fireballcnc is on a distinguished road
What software?
Full?...Half?...Microstepping?
John
Old 08-30-2007, 05:08 PM
*Registered*
Mach3/Quantum
1/8
Old 08-30-2007, 05:50 PM
So your "steps per" in Quantum motor tuning is 16000?
Did you try half or 1/4 stepping? You'd go faster..
My screw is 1/2-10 acme...I use Geckos at 1/10 step.
Just for comparison, My Velocity is 125 and accel is 30. I can go
90 IPM easy.
John
  #11   Ban this user!
Old 08-30-2007, 06:19 PM
Just noticed you said you're using the Keling 4030 drivers and
you'd upped the voltage to 55??
It says they're for 24-40VDC.
Maybe I'm missing something?
John
Old 08-31-2007, 06:04 AM
*Registered*
started at 24 and they barely moved so slowly but surely the voltage has crept up to 55, looking at the drivers they should be able to handle 80 reliably but the motors would cook.
gearing question again timmyb199 CNC Plasma and Waterjet Machines 15 09-30-2006 03:39 PM
Gearing down... snooper Mechanical Calculations/Engineering Design 9 08-02-2006 11:26 PM
Rack gearing? DennisCNC Linear and Rotary Motion 1 05-17-2006 09:36 PM
Need help on Gearing CAM_MAN DIY-CNC Router Table Machines 8 04-05-2006 12:23 PM
Reduction Gearing & Backlash UKRobotics DIY-CNC Router Table Machines 2 04-02-2004 01:31 PM
