#14
Very interesting , thanks for the reply. |
#15
Hello, I've started with the idea of building a PCB mill with 10x16cm working area (Eagle light limitation, more than enough for 90% of my PCB's). I've ended with a mill with 15x21cm working area, and 7cm of Z travel. Working good until now: attached a sacrifice MDF, and leveled the working area. Pictures represent: - whole mechanical CNC - nut-spring-nut used for Y axis - controller + manual jog + bipolar drivers for steppers (controller = CNCUSBController from Kroko) - stepper drivers = A3979 based, and are working amazing from a 12V power supply - RC outrunner used as spindle for milling PCB's (has 3.17mm inner bearing diameter ), well.. milling PCB’s needs only about 15W of power!!!- 2x12V,2.5A power supply - one for controller and one for spindle - I intend to put all electronics part on the back of machine - a small PCB milled just for test (the one with larger isolation tracks was obtained by running the same g-code for about 15 times, just to see what will happen); note: there is no software compensation for backlash! Merry Christmas to you all! |
#17
| Looks great guess I will have to start on one here shortly. Love all these post with very positive results. I have a dremel and a sears 1/4" router and will use those as proto types. if all works good then I would start a search for the famous porter cable 1/2". |
#21
| It's working good, since I can set the speed of motor with a small potentiometer. |
#23
I know Voltage, Kv constant of the motor, and position on the potentiometer. (sometimes, at the begining, I have measured real speed of the motor in diverse circumstances) |
#24
kV rating of the motor (provided with 99.9% of all RC brushless motors) multiplied by voltage gives you the approximate RPM, assuming 100% efficiency and no load of course. |
| Tags |
| homemade, mill, pcb |
| Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head | fignoggle | Benchtop Machines | 18 | 05-11-2009 11:11 PM |
| Home Shop: Mill, Router or both? | biomed_eng | Polls | 7 | 12-15-2006 09:18 AM |
| home built cnc router | sanjiv | DIY-CNC Router Table Machines | 5 | 08-17-2006 03:43 AM |
| Another home built router :) | steveald | DIY-CNC Router Table Machines | 69 | 03-19-2005 12:22 PM |
| purchase or building a home cnc router. | s_bedow | DIY-CNC Router Table Machines | 9 | 03-19-2005 12:22 AM |
