Old 08-12-2007, 11:15 AM
rooter is on a distinguished road
Average Costs To Build
Hi, I am thinking of building or buying a cnc router. I would like something around 4'x4'. I can get a used shop bot for around $5,000. If I was to build one I would make it from 80/20 extrusion, with aluminum plate, and vbx linear guides. No wood. How much money has people been sinking into their setups. I would hope to be under $3,000 up and running. So, what do you guys think. Drop 5,000 and have something up and running or build and save some money if possible. Thanks in advance for any suggestions.
Old 08-12-2007, 12:57 PM
Eurisko is on a distinguished road
$3000 is definitely doable, but it depends on the components you use.
[Ballscrews] [acme rod] [rack & pinion]
[stepper motors] [servo motors]
[budget drivers] [top-end drivers]
[new components] [used components]
Are you planning to make any of the components you'll need?
I'm going the cheap route,
used Thomson shafts & bearings
stepper motors, acme rod, steel and aluminum plate, cheap electronics, some used components, plus a lot of elbow grease (and time)
I've probably got about $1500 invested.
The final total will be under $2000.
The final build will be 48x36 OR 36x24
Would be nice to use higher-end components, but that will have to wait for version 1.2
Old 08-12-2007, 01:11 PM
I would be using the vbx 20 mm linear slides on all movements and acme screws as they should not be real pricey. Steppers mounted directly to screws. The 80/20 material to make the table may be costly. If the mechanical part turned out ok then I would get decent steppers and electrical components. I just hate to start the project and then wind up with a bunch of cost and head aches.
Old 08-12-2007, 01:43 PM
ger21's Avatar
You might want to look at the mechmate, http://www.mechmate.com/
Old 08-12-2007, 06:53 PM
rustamd is on a distinguished road
Mine will cost me about $2300. Its completely made out of aluminum. Rails are bosch rexroth, gear rack with 3:1 reduction, keling steppers and drivers etc. ~36"x28" working area. Here is a sketch:
Old 11-15-2007, 10:24 PM
Monster is on a distinguished road
rustamd you design has some flaws
Old 11-15-2007, 10:27 PM
yep, so does everybody else's
Old 11-16-2007, 01:10 AM
andy_ck87028 is on a distinguished road
beautiful ... just beautiful.
I enjoyed your response. Go for it.
Andy
Drat, imperfection has finally stopped working!!
Old 11-16-2007, 01:24 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Maybe it is me -
I don't see rustmamd sketch
that must be my flaw
For the Haiku innocent ; )
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 11-16-2007, 01:26 AM
its there, at least for me, but if you dont see it go look at my build log
How much does an average machinist make? tomekeuro85 CNCzone Club House 214 05-20-2012 08:54 AM
Now Hiring to build a 4'X4" router $500 + material costs-RFQ midevilone Employment Opportunity 2 11-18-2008 07:21 PM
average rates for mold components championp Moldmaking 15 09-03-2006 07:20 PM
Series 2 average price sped1111 Bridgeport and Hardinge Mills 1 01-09-2006 09:40 AM
1/4-20 average speeds? ShayArnett DIY-CNC Router Table Machines 5 12-24-2004 01:17 AM
