Old 08-09-2007, 02:10 AM
dbtoutfit is on a distinguished road
Routing 1/32 thick sheet metal
So I need to cut a few holes/circles (13/16 and 1/8) in some sheet metal with my router cnc.
If it helps at all it's the exact same sheet metal used for Computer PSU's.
I need to know what type of bit I can use to do this?
These metal burs bad too. I have been using a drill press with a tapered bit I grabbed from Lowes that sizes it bigger in steps the deeper you drive the bit. I forget what the bits called but anyways.
I have mostly small carbine bits. 1/32, 1/16 and so on. But I am thinking these have the wrong flutes.
I just don’t know lol
Any help would be nice.
Thanks guys
Theres a good side to every bad side, you just have to look around the corner.
RFG - FOAM SHEET ROUTING in MELB AUSTRALIA clp Employment Opportunity 1 10-26-2006 11:33 AM
RFQ for Sheet Metal Work Rob_M. Employment Opportunity 6 02-13-2006 01:14 PM
Routing Alu sheet ScuD DIY-CNC Router Table Machines 9 09-26-2005 07:17 AM
Thin sheet metal itsme Welding, Brazing, Soldering, Sealing 9 03-01-2005 03:24 PM
Routing Aluminium sheet kong DIY-CNC Router Table Machines 11 06-10-2003 12:51 PM
