hello every one i want to machine aluminum and timbers with my machine i was wondering what you guys thought of this controller ![]() http://www.oceancontrols.com.au/moto...en_r_2_513.pdf i am also unsure of what motor to use i was thinking of ![]() MO-103 Stepper Motor - 23HD803 (Now Back in Stock) This motor, the largest of the 56mm range provides a holding torque of 1.6 N.m (222oz-in) and is suitable for heavy operation. Features • Rated Current: 0.6A • Step angle: 1.8deg • Ambient Temp -10 to 40degC • Temp Rise 85degC • Dimensions: 56mm x 56mm square face, 76mm long, 47mm between mounting holes • Weight: 1.1Kg http://www.oceancontrols.com.au/moto...th_23HD803.PDF ![]() MO-105 Stepper Motor - 57HS22 (Now Back in Stock) This motor is a 23 Frame motor with 4 phases which you can wire in parallel or serial provides. It has a a holding torque of 2.2 N.m (311oz-in) and is suitable for very heavy operation Features • Rated Current: 2.8A (Series), 5.7A(Parallel) • Phase Resistance 1.6ohm • Phase Inductance 7.2mH • Step angle: 1.8deg • Ambient Temp -10 to 50degC • Temp Rise 80degC • Dimensions: 56mm x 56mm square face, 80mm long, 47mm between mounting holes • Weight: 1.2Kg • Shaft extends 20mm from both ends of the motor http://www.oceancontrols.com.au/motors/stepper/57HS.pdf |
| Hi, I use stepper drives from the same manufacturer and am very happy with them. You need to keep in mind that if you are going to route timber you will very likely want to wire your stepper motors bipolar parallel if you are directly driving the screw. The first motor has a high phase inductance 43mH and volts rating so would not recommend it for your application. The second motor if run bipolar parallel would need a higher Amps rated drive (5.7+Amps) to get anywhere near the rated holding torque. Without knowing the specs of your machine it is not really possible to recommend a stepper motor. There are programs and threads that help calculate the power you would require for your machine so a good search or if anyone else can link to a thread would be the place to start. Then look for the best stepper motors that meet your needs and drives that match your motors. Hope this helps, ![]() John |
| I have the Hobby cnc pro board (4 axis) on a foamcutter with 80 oz. steppers. I am now looking at converting my mill/drill using the 305 oz. steppers as I learned quite a bit from the first project.(still learning) If I am not mistaken your controller power supply is 12 or 24 volts. The HCNC board will go up to 42 volts and 3 amps per axis. My feeling on this is if you use a 24 volt transformer and after you get it regulated you will be well over 24 volts. I would do some checking before purchasing. I would also reccomend taking the info previous and build your machine before ordering your electronics. Bit of a problem if you change mid stream and try something else. John |
| Bridgeport steper motors | hello113 | Bridgeport and Hardinge Mills | 1 | 07-11-2006 12:07 AM |
| What Controllers and Motors should I get?? | RMS | DIY-CNC Router Table Machines | 29 | 06-29-2006 07:18 PM |
| USB Controllers & Integrated Stepper Motors | tt_raptor_90 | Stepper Motors and Drives | 0 | 01-29-2006 04:59 PM |
| The theory behind stepper motors and controllers | abasir | General Electronics Discussion | 1 | 07-22-2005 04:15 AM |
| Sources of Motors/controllers | bill south | Servo Motors and Drives | 1 | 05-05-2005 11:06 PM |
