Old 04-27-2004, 03:36 PM
starCNC is on a distinguished road
What size of drill bit can be used for 1/2-10 acme tap?
Old 04-27-2004, 03:40 PM
Cold Fusion is on a distinguished road
.4130
Proud owner of a Series II Bridgeport.
Old 04-27-2004, 03:49 PM
where can i find that kind of drill bit?
Old 04-27-2004, 04:18 PM
duluthboat's Avatar
duluthboat is on a distinguished road
Look for a letter Z drill
Gary
Old 04-27-2004, 08:53 PM
ger21's Avatar
What are you tapping? I tapped Delrin with a .375 hole and a homemade tap.
Old 04-27-2004, 10:32 PM
Yes, i am trying to make an anti-backlash nut using delrin.
Old 04-27-2004, 10:40 PM
Was it hard to tap though with that size of hole(.375)? should i go for .4 drill bits?
Old 04-27-2004, 10:42 PM
Also, can you guys give some info on how to make my own acme tap?
Old 04-28-2004, 07:14 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
starCNC - a couple of times there have been some great how-tos re Acne Taps - including homemade ones on the site - you could use the search or just check out these 2 for starters:
what acme tap do I need for the Enco ACME rod?
and
Acme Tap
its real easy and works great - the taps I mean...
cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 04-28-2004, 07:57 AM
TimW is on a distinguished road
Acme taps and rod
Is Acme a trademark brand of rod, or a generic term ?
Thanks.
  #11   Ban this user!
Old 04-28-2004, 09:52 AM
duluthboat's Avatar
Acme refers to the shape of the thread that in general terms is smother operating and stronger.
Gary
Name:	acme form.jpg‎
  #12   Ban this user!
Old 04-29-2004, 05:36 PM
brickman's Avatar
brickman is on a distinguished road
I have always wondered how this was done. Thanks guys. This helps a lot.
Tap Drill Calculator Freeware Rekd Product Announcements & Manufacturer News 35 11-15-2011 04:37 PM
Multi Bit Drill Head smythe WoodWorking 0 11-16-2004 12:02 PM
Acme leadscrew size selection info jeffs555 DIY-CNC Router Table Machines 0 06-13-2004 09:31 AM
what acme tap do I need for the Enco ACME rod? AJ_Mac2001 DIY-CNC Router Table Machines 15 03-08-2004 07:24 AM
Acme Tap georgebarr DIY-CNC Router Table Machines 14 02-25-2004 11:06 PM
