Old 04-27-2004, 09:06 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
Typical power supply
Here is a picture of a typical power supply.
The box at the top has all the capacitors in it. You can use one big capacitor or many smaller capacitors wired in paralell. It is often cheaper to have many smaller capacitors than one big one that equals the same value. When designing your power supply it is recomended to have 2000uf capacitance for every amp your transformer can deliver. Example, a 30 amp transformer would require 60,000 uf capacitance.
You will note the heat sink at the top. This is to cool down the rectifiing diodes. A typical power supply requires 4 diodes arranged in such a way to convert a AC current to a DC current. The arrangement is called bridge rectification.
Other electronic parts you can add but are not absolutely essential are, a bleeder resister that will slowly disscharge the capacitors when the power supply is off. Also an electronic device called a MOV can be used to protect your circuit from power surges. A MOV will short out over a specified voltage and take the punishment instead of your circuit.
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 03:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 09:05 PM
Is this power supply rating adequate? jerryrigge General Electronics Discussion 3 11-25-2004 10:06 AM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 10:36 PM
