Am awaiting a 24v 6.5amp power supply so I decided to do a test. I have some 116oz bipolar stepper motors and using Xylotex control board. While waiting for some parts to complete my cnc router I decided to perform a drive test. Using a 12v, 7amp switching power supply from a computer (instead of 24v) I connected controller and motors, and as instructions said I set the VRef to about 3.6volts. I was dissapointed to see that the stepper motors lost quite a bit of steps. In my test setup the motors were connected to the screws but not to anything else. I always believed that it was amperage and not voltage that provided the torque, but was easily able to get them to loose steps with just a little bit of drag by pinching the screw with my finger tips. Was this a valid test? and will the 24v power supply really make the difference? |
| Can you turn the screws with your hand when they are not spinning? With the lower voltage, you'll have full torque when the motor is NOT spinning, but torque will fall off very rapidly as rpm's increase. 24V will keep the torque up at higher speeds. 24V should double the speed your getting with 12V. Did you wire the motors parallel or series?
| I meant with the 12V turned on. They should be holding strong enough to keep you from turning them.
| How does a power supply work. | ynneb | DIY-CNC Router Table Machines | 1 | 07-27-2011 09:40 AM |
| Diy Power Supply Choices | berin | DIY-CNC Router Table Machines | 11 | 07-13-2005 03:47 PM |
| 5 Volt Power Supply Tripping | murphy625 | General Electronics Discussion | 13 | 02-27-2005 09:05 PM |
| Is this power supply rating adequate? | jerryrigge | General Electronics Discussion | 3 | 11-25-2004 10:06 AM |
| Choosing a Power Supply for Retrofit? | pfeist | General Metal Working Machines | 4 | 05-23-2004 10:36 PM |
