Old 04-26-2004, 02:25 PM
signIT is on a distinguished road
How to make the frame exact
I wonder about how to make a frame for the linear slides that are exact in measure.
What I mean is if the frame is a little bit offset i may make the linear slides a bit hard to move when the gantry is mounted.
Even a small tension can be a big problem how does the professionals make a frame that have high precision.
I think that a steel frame that is assembled with bolts is the best.
Can any give me a good construction information.
Old 04-26-2004, 08:30 PM
ger21's Avatar
If you build it out of steel, here is some info on how to get it VERY flat.
http://www.lmwatts.com/straightedge.html
Old 05-01-2004, 02:13 PM
berin is on a distinguished road
http://cnczone.com/forums/showthread...3012#post33012
Here is a post of mine which tells how to make a straight rail alignment. post number 25
Old 05-27-2004, 11:18 PM
kanankeban is on a distinguished road
Gerry,
It will be great if you could help us out with some visual content in the explanation on how to get flat surfaces, Sorry I read it several times but I can't get it right.
Regards...
Hector
Old 05-28-2004, 07:53 AM
ger21's Avatar
I didn't write it, and I'm not sure if I've ever even read the whole thing.
Old 05-28-2004, 02:04 PM
flat surface
I have an idea I will mount my THK rails on a thin wall square steel tube using soft metal shims that should take up some missalignment in the steel surface, also the thin tube steel will help a lot to hold the rails straight and flat or...?
How to make Parallel Square Beam/pipe without flat surface ? Calico Welding, Brazing, Soldering, Sealing 8 06-26-2005 08:13 PM
How do you make Bridgeport execute program? Bill Gillen Bridgeport and Hardinge Mills 10 06-14-2005 08:26 AM
Time to make it work DESERT RAT DIY-CNC Router Table Machines 8 02-22-2005 07:30 AM
Software to make Xsections of an .STL file BK2_SHOOTER Printing, Scanners, Vinyl cutting and Plotters 0 12-21-2004 02:19 PM
how do i make a .cnc file? ljoe1969 TurboCNC 3 01-14-2004 08:56 PM
