Old 07-23-2007, 10:39 PM
rianmullins is on a distinguished road
Which router bits to use on a cheap homemade CNC route?
I'm putting together a CNC router from David Steele's designs, and am wondering what kind of bits people have the best luck with when cutting wood.
I'll be using a small 1-hp variable speed Bosch router with a 1/4" collet.
I'm inclined to use 1/4" ball end or corner-rounded end-mills. Are end-mills good for cutting wood? Or are router bits somehow better? (What's the difference? ) I assume 1/4" is the right size because people seem to be using small routers with 1/4" shanks in their machines.
What about roughing end-mills? The ones with all the jagged bits on them. They look like they might make quick work of cutting wood. Although I can't seem to find them in 1/4".
Should I use many flutes or a low number of flutes? And should the helix be high or low?
I guess straight router bits tend to have 2 flutes and a low helix, so that's probably the right thing for cutting wood. But are straight router bits even center-cutting usually?
I'm leaning toward the roughing end-mills right now, because they seem like they would shred the wood nicely, minimizing forces on the router caused from tearing into he grain.
Thanks for any info/ opinions.
Rian Mullins
Old 07-23-2007, 10:48 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
i buy the cheap bits from kms tools , they go on sale really cheap (3 bucks )
router bits are cheap once you find the right supplier
i would recommend you not use endmills on wood , i nearly lit up my first machine ,
a 1/4" endmill i was using created a lot of friction because of the bit clogging and it lit up the mdf dust , if i wasnt right there it could have been ugly
Here is my new homemade router ahmed CNC Wood Router Project Log 8 12-09-2006 12:17 PM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
Another Homemade CNC Router southernexplore DIY-CNC Router Table Machines 0 02-18-2006 08:59 PM
Where to buy CHEAP PCB milling bits abasir General Electronics Discussion 12 04-17-2004 09:14 PM
Where to get cheap parts for a Homemade Router teilhardo DIY-CNC Router Table Machines 3 03-14-2004 08:09 PM
