Ok, Now I need to build a vacuum hold down for my table, my power options are 220v/110v single phase. I will mill 4 zones maybe 5, what options are there besides a regenerative pump. It must run on 220 and support a 4x8 foot surface. |
| I am not sure about the area you live in, but around here, there are a lot of used vacuum pumps on the market. The semiconductor market especially uses a lot of them. Almost any of them will pull at least 1/2 atm for high volume. Lower volume ones in reasonable sizes will go lower, but going to less than 1/10th of an atmosphere is probably not worth the size / price. A single or dual stage oil filled pump will work fine. You might even get away with a small roots blower type. There are a few higher end vacuum cleaners that have pretty strong motor / turbine setups - usually the canister types, like a Princess or some of the German house vacuum systems made with HEPA filters. (the one I am thinking of starts with an "M", but I cannot remember the name) These can be found mostly at small, local vacuum repair stores. I have been told that some of the older Kirbys could pull the carpet away from the wall, so they had to "weaken" the suction. I would not bother with ANY upright vacuum motor / fan setups. Even the pricey ones are not that powerful. |
| Full vacuum, about 30" Hg which is impossible to get, gives you a hold down force of 14.7 psi or just over 2000lb over a square foot. A really good vaccum pump will pull 27", maybe a bit more, without any leaks. As soon as there is any leakage the vacuum is lost very quickly because it can take a very large pump to overcome even small leaks and give a good vacuum.
| Vacuum table and vacuum pump | garagefela | DIY-CNC Router Table Machines | 19 | 01-25-2012 10:30 AM |
| Vacuum Hold down for wood. | HomeCNC | DIY-CNC Router Table Machines | 46 | 07-23-2007 11:16 PM |
| Vacuum hold-downs and rotational problem about the z axis | cpcp | Work Fixtures and Hold-Down Solutions | 5 | 12-08-2006 07:02 AM |
| Vacuum system to hold down paper | Aan | Open Source CNC Machine Designs | 2 | 04-06-2006 10:13 AM |
| How to hold | MIKEB | Work Fixtures and Hold-Down Solutions | 12 | 09-04-2005 08:50 PM |
