Old 04-26-2004, 12:39 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
More bolts than the Sydney harbour bridge.
I am so close to been finished. All I have to do is wire it up.
I have run each axis as a temporary set up and it runs great.
A few limit switches and a router and its finished. I recon 4 days away maximum.
I know it is a horror to any true engineer, but I am happy for my first attempt.
Old 04-26-2004, 01:10 AM
Hobbiest is on a distinguished road
Don't look like any horror to me! A bid like an Erector Set, sure, but at least you are almost done.
Stop talking about it and do it already!!!!!
Old 04-26-2004, 03:15 AM
IJ. IJ. is offline
Gold Member
IJ. is on a distinguished road
What ratio are your belt drives Benny?
Old 04-26-2004, 04:03 AM
ynneb's Avatar
Moderator
The ratio is only 3:1
I was hoping to gear it down more but it ws going to be too expensive and too much of a hassle.
It would have meant double reduction gearing. It still pulls very hard...I cant stop it with my body weight.
Old 04-26-2004, 05:14 AM
IJ. IJ. is offline
Gold Member
Thanks Benny,, what size pullys did you end up getting?
Old 04-26-2004, 06:52 AM
ynneb's Avatar
Moderator
The pulleys are 20 tooth : 60 tooth 2.5 inch diameter : 7.5 inch diameter x .75 inch belt size
Old 04-26-2004, 07:11 AM
IJ. IJ. is offline
Gold Member
Pitch?
Just asking cos I went for 15/30 and 15/60 x 5 mm Pitch and my 60 looks much smaller than yours.(also trying to get an idea of scale for your machine as it's hard to tell by the pic)
(my guess going by the PIES catalog is 10 mm pitch)
Old 04-26-2004, 07:21 AM
ynneb's Avatar
Moderator
Now I am showing ignorance. I dont know the pitch and I really dont know what that means. I am presuming it is the distance between the teeth. I measuered from the center of one tooth to the center on the next tooth and its 10 mm ( Gee I prefere metric talk )
Measuring from the bottom of the gantry to the top of the top servo is 850mm.
How is your machine going anyway? Why dont you post a picture.
I might request for this thread to be moved to the Aussie forum.
Old 04-26-2004, 03:54 PM
balsaman's Avatar
balsaman is on a distinguished road
wow,
How does the rack and pinion work? That thing will fly.
Eric
I wish it wouldn't crash.
Old 04-26-2004, 04:35 PM
IJ. IJ. is offline
Gold Member
Benny: Bingo you're correct it's the distance between teeth !
I now have all of the parts I need to assemble my machine just not the time to do it yet!
I picked up the longer ballscrew I needed last week and once I finish work on a run of production parts I'm doing now I'll get stuck into it.
I intend posting a detailed step by step in the Aussie room once I start on it (it's killing me having all these cool parts sitting there and having to use my manual machine)
Let me know here when your machine is up and running and I'll pop over and have a look at it working if that's ok with you (I'm only 10 minutes away).
click to enlarge
  #11   Ban this user!
Old 04-26-2004, 05:11 PM
vacpress is on a distinguished road
benny
thats looking good - the last thing i saw from you was just the frame - start a thread and post more pics! you are where i want to be.. i have very limited $$$ though, so its slow...
q: are those the cliftons?
q: what is the resolution with the 3:1 reduction and your.. rutex? drivers right?
q: what is the encoder CPR? are they the USdigital encoders?
q: what else do you want to tell me?
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
Old 04-26-2004, 05:24 PM
ynneb's Avatar
Moderator
IJ.....you wretch......all this time youve had that mill and have been so close to my house. I've had to mill things with a hand drill going sideways. Ahhhhhhhhhh
Glueing bolts in...Liquid lock-washer? samualt DIY-CNC Router Table Machines 3 10-04-2004 11:32 AM
