Old 07-22-2007, 03:43 PM
luther is on a distinguished road
Question stepper motor
whats the maximem rpm a stepper motor can turn?
Old 07-22-2007, 03:57 PM
ger21's Avatar
It will vary greatly depending on a lot of things. At it's maximum speed, whatever it may be, it will have virtually no torque at all, since a stepper motors torque drops off as rpm's increase. The voltage supplied also has a lot to do with it. Typically, a stepper will be able to spin it's fastest with the highest voltage possible supplied to it. However, the higher the voltage, the hotter the motor will run. Run it too hot and you will destroy the motor.
Larger motors will typically not spin as fast as smaller ones. For a machine use, NEMA 23 motors will usualy be able to spin faster than Nema 34's.
The drive used also factors in, as well as what you're using to create the step and direction pulses. A lot of times that is the limiting factor.
For a given application, your best bet is to figure out houw much torque you need at a given speed, and pick a motor who's torque curve fits the application.
Just a guess, but I'd say most use their steppers at 1000-1500 rpm max, and a lot use them even slower.
As for the Max a stepper can spin, I've heard of steppers spinning at 10,000 rpm while being tested in a lab, but has no bearing on their use in a machine.
Stepper motor toneV8 Stepper Motors and Drives 21 03-24-2009 05:28 AM
Stepper Motor Kelinginc Product Announcements & Manufacturer News 0 02-03-2006 12:56 PM
Stepper Motor Help Ayjay Stepper Motors and Drives 6 03-14-2005 03:31 PM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 05:05 PM
need help with stepper motor oldpoopie Benchtop Machines 5 11-20-2004 08:04 AM
