Old 07-21-2007, 08:20 PM
Mr.Nerd's Avatar
Mr.Nerd is on a distinguished road
Cutting hardened shafts
What are the easiest ways to cut a hardened steel shaft? From my understanding, larger shafts are generally just case hardened right? You think it could possible be cut on a lathe with the right cutting tool?
Old 07-21-2007, 08:31 PM
Dar Dar is offline
Dar is on a distinguished road
yes several years ago i had a job making 14in pins from 24ft. pieces of thompson shafting. i used a carbide insert threading tool to initally cut through the case then a parting tool to finish. these shafts were 2.5 in in dia.
i used coated carbide
good luck
Dar
Old 07-23-2007, 05:48 AM
andy_ck87028 is on a distinguished road
I put this same question up recently and got heaps of good suggestions.
Try: cutting 10mm hardened steel shaft?
Andy
Drat, imperfection has finally stopped working!!
Old 07-23-2007, 01:05 PM
Stahl Gear is on a distinguished road
Exclamation Imperfection!?
No. All of our resources (mechanical and human) are concentrated in one location. Keeping all of our manufacturing equipment, raw material, knowledge & expertise, and our inventory of finished and semi-finished goods all together in one location gives us the maximum diversity in our manufacturing capabilities. With our large facility, http://stahlgear.com huge supply of raw material stock, in- house machining and fabrication, extensive tooth cutting and comprehensive induction heat treating Linn Gear has the capability to manufacture products in-house from beginning to finished product. This saves end users time and money.
Old 07-23-2007, 01:11 PM
#3 Today, 05:48 AM
andy_ck87028
Apprentice Join Date: Dec 2004
As did I, put this same question up recently and got a lot of good answers.
Try: http://www.stahlgear.com
Jason
Old 07-23-2007, 01:12 PM
Jason
Old 07-24-2007, 05:23 PM
Mr.Nerd's Avatar
Thanks for the replies. I think I will try doing in on a lathe when the time comes. Im a student so I have access to universtiy machine shop.
Cutting hardened Thompson Rail. pbunnstf General Metalwork Discussion 5 07-09-2007 07:19 PM
cutting 10mm hardened steel shaft? andy_ck87028 Mechanical Calculations/Engineering Design 5 06-24-2007 08:12 PM
Cutting Hardened Steel Smackre CNC Plasma and Waterjet Machines 0 02-08-2006 01:12 PM
joing two shafts dobber5810 General Metalwork Discussion 0 01-28-2006 06:19 AM
sagging shafts smarbaga Mechanical Calculations/Engineering Design 10 07-01-2005 10:05 PM
