Old 07-19-2007, 08:47 PM
JeffW47 is on a distinguished road
Need z-axis help
I am new to CNC and had a question about adjusting the depth of the z-axis throughout a cut. I will be desigining in adobe illustrator. How would you adjust z-axis to print characters on a part and then chane the depth to cut out the part?
Old 07-19-2007, 10:25 PM
johnmac's Avatar
johnmac is on a distinguished road
You will need to set the Z depth in the program that creates the G code, like Mach or Kcam.
I have read about creating in layers, then saving the layers as seperate files, each to be used with a different cut depth.
I too am new at CNC. I know my way around Illustrator, but not cad programs. So far I have not had good results with DXF files from Illustrator. They don't come out the right size when opened in a cad program. (?)
John
A 5-axis CNC machine including a rotary axis synthetiklone CNC Wood Router Project Log 11 05-23-2012 09:31 PM
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
4 axis controller for 3 axis machine? tybrenis CNCzone Club House 8 01-19-2007 09:12 PM
Options for 2 Axis Head (to make 5 axis) drewgarth DIY-CNC Router Table Machines 6 07-12-2006 12:37 AM
