Hello guys I am working on the z axis for my machine. I have some ebay (IKO) rails that I thought I would use for the Z axis. I only plan to use one rail with the cutter being attached directly to the rail. The screw will be below it for the movement. This is a 1 inch rail travel 7-8 in. What do you guys think? Will the rail be sturdy enough? Any other foreseeable problems? Dimensions for the whole machine will be about 28X40 Ill try to attach a pic thanks Kev |
| Two blocks would be better, but it should work OK, provided the rail is mounted very solidly. Our 10HP routers at work are on a single 25mm rail with 2 blocks.
| Motorized Z Axis - Advice | ADucci | Linear and Rotary Motion | 1 | 07-02-2007 10:56 AM |
| Some advice needed on X-Axis belt issues. | kumaichi | Industrial Hobbies (Support forum) | 14 | 02-21-2007 08:47 AM |
| Bridgeport 2 axis EZtrac+ advice | John Wood | Bridgeport and Hardinge Mills | 2 | 09-12-2006 09:24 AM |
| Sieg X3 Z-axis Conversion advice wanted | Bird_E | General Metal Working Machines | 22 | 11-27-2005 08:06 PM |
| Add a second set of rails to X axis..need advice. | bgolash | DIY-CNC Router Table Machines | 5 | 05-31-2005 07:11 PM |
