Hello, Im thinking of combining a hobbycnc 4axis driver and the following stepper motor http://cgi.ebay.co.uk/ws/eBayISAPI.d...5862&rd=1&rd=1 with this power supply (36v 9a+) http://cgi.ebay.co.uk/350W-36V-9-7A-...QQcmdZViewItem Does anyone know if its compatible? Is 9amps too much? Thanks |
| the motors will only draw what curent they want, think about the national grid how many amps is that? but your light bulb only uses what it needs ![]() voltage will work but 20 times rated stepper voltage would be better, but then I don't know the board, perhgaps that is only rated to 40volts...
__________________ www.la-coterie.com for holidays in France |
| The board maxes out at 42volts. So if I were to run a 2 X axis, y and z would I need to add the ampage of the motors together to calculate which supply I would need. The motors run unipolar at 2.8v 2.8amps. Would that mean if x,y and z were running I would need at least 11.2amp power supply? 4 motors at 2.8amp? |
| Well yes that's how it adds up but... and there's always a but you're never likely to have all 4 motors going at once flat out demanding all that current so in short then that power supply will be fine. There would be no harm in using a bigger amperage power supply if you found one...motors draw more current the harder they have to work
| Some power supply and driver Questions | gone4pepsi | Benchtop Machines | 2 | 03-21-2007 10:48 PM |
| Step Motor Driver and Power Supply Wiring | mcan | Open Source Controller Boards | 3 | 01-19-2007 04:22 AM |
| Step Motor DC Power Supply | BobWarfield | General Electronics Discussion | 9 | 09-18-2006 07:23 PM |
| Driver, PC LPT and power supply schematicas | msnarouz | Stepper Motors and Drives | 3 | 07-29-2006 09:11 PM |
| Driver and Motor Power On Dangers | mannster | General Electronics Discussion | 3 | 04-23-2005 03:26 PM |
